Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water filter location
Where is the water filter located on this thing? I can't even find it to replace it.
Underneath the fridge side it is a circle on the bottom
Posted on Aug 23, 2008
Ice Maker works but water dispenser doesn't
The solenoid valve is located where the water line connects to the fridge. There is a micro switch that the paddle in the door operates when you push a glass against it. Sometimes the plastic locating pin that holds the switch in position breaks and allows the switch to move away from the actuating lever.
Aug 26, 2017 | LG Refrigerators
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Jun 12, 2011 | Maytag MFF2557HES Stainless Steel French...
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
Where is the water filter located on a kitchenaid ksrp25qdwh00
This particular water filter is known as a ``in line water filter`` and is located at the BOTTOM of the fridge at the LEFT hand side. located in the grill at the bottom. first you must remove the filter cap and then It simply twists out for easy replacement. part number for the water filter is 2255519. and should be replaced based on a 6 month period or the amount of water filtered. hope this helps
Thanks
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Where is the water filter located on the Samsung SRS2028CSS
The water filter is located in the
upper right-hand corner of the fresh
food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from end
of filter and insert into filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs steady. During initial
use, allow about a one- to two-minute delay in
water dispersal to allow internal water tank to fill.
Sep 10, 2009 | Jenn-Air JFC2089HT Bottom Freezer French...
I am sending this picture to show you where the filter is located. Hope it helpsa you. Please let me know. The filter is #28
Jul 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water not coming out
Without knowing the model # filter is usually located on bottom of fridge in grill. When you depress the lever listen for the water valve in back of fridge to click on if not you may need a new water valve. What is the age and model # of fridge?
Nov 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water in the fuel
Evidently you got water in the sensor connecter. The fuel filter is located on the right side as viewed from the front of the engine about even with cyl 4. unplug the sensor in the bottom of the filter and blow it and the connecter out with compressed air and plug back in, this should take care of your problem. Since you know know where this filter is it needs to be drained and/or replaced from time to time when this light comes on also.
Aug 03, 2008 | 1994 Dodge Ram 3500
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
157 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
