Question about Canon Office Equipment & Supplies
Sheets of paper have stuck under the ink cartridge on the printer. It is not operating now.\ How can I remove the paper?
    Guru:
  • 352 Answers
Hello.
Depending on the model of printer will depend on the removal. If the printer takes two cartridges pulling them up and back should remove them.
If it takes a cartridge for each colour, remove each ink tank, then lift the leaver on the side of the tank holder inside the printer. the print head should be able to be lifted out and the paper should slide out easily.
I hope this helps Regards GM
Posted on May 28, 2011
Printer error 6000
follow this instruction and fix it. God bless you
  • 1
    Make sure that the printer is connected to a power outlet. The power cable should be connected in the back of the printer and to a working electrical socket.
  • 2
    Check that the wire from the printer is running to the correct port on the computer tower. The wire runs from the small, square port on the printer to one of the USB ports on your tower or laptop computer.
  • Sponsored Links
  • 3
    Turn the printer on. Much of your printing failures can be avoided by making sure that the power is turned on before selecting the print command.
  • 4
    Install any updates or replacement software needed to run your printer on your computer. You can get this software from the manufacturer's website and will be notified through your printer drive if there is something new to download.
Feeder Problems
  • 5
    Pull out all of the paper supply in the printer and make sure that all pieces of paper are flat and whole. Any folded corners, crumpled sheets or torn pieces should be thrown away.
  • 6
    Check the size of the paper you are using and check the paper guide on the supply to make sure the paper is the correct size. The paper guide is the small plastic clip that holds the paper steady in the feeder.
  • 7
    Open the cover of the printer and make sure there is no paper stuck within the feed rollers. You should pull out the jammed paper if there is any, including any little torn pieces that may be stuck inside.
  • 8
    Clean out the feed rollers with compressed air to remove any dirt inside the printer and refill the paper supply.
Ink Problems
  • 9
    Check the ink levels in your cartridges to see if you have to replace the ink. You can do this through the control panel of your printer software. If you don't know where to find these controls, just search your computer for 'printer drive'.
  • 10
    Open the cover of the printer and wait for the ink cartridges to stop in front of you within the printer. This will allow you to take them out and replace them with full ones.
  • 11
    Pull the cartridges out of the printer. The number of cartridges and how to remove them will vary with your model of printer, but usually there is a small clip holding the top edge of the cartridge in place. Just push this clip back and pull the ink out.
  • 12
    Pull the protective seal off the head of the new ink cartridge. This is where the ink comes out and when you pull off the seal it will allow the ink to descend.
  • 13
    Drop the ink cartridges into the printer and push each cartridge into place. If there are clips you will hear them click when the cartridges are in place.
  • 14
    Run a diagnostics test on your ink heads if your ink problems persist after refilling the ink. This will help you clear out the heads.
Read more: http://www.ehow.com/how_6789824_troubleshoot-canon-printer-problems.html#ixzz2ZRL06I56
Jul 18, 2013 | Canon iP2700 Inkjet Photo Printer
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
Red light under ink cartridge
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Mar 19, 2012 | Lexmark X8350 All-In-One InkJet Printer
Will not load paper,when it does it prints for ****.how do you check ink cartriges
Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the printer cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert the cartridges. Load some paper and try to print again.
To check the ink levels using your computer, Click Start menu > Programs or All Programs > Lexmark 2500 Series > select Lexmark Solution Center. In the main dialog screen, the ink levels are displayed.
May 08, 2011 | Lexmark X2500 All-In-One Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
My lexmark x 3650 states there is paper jam. it never happened. i was low on black ink but have just replaced cartridge. how do i clear/
Try to remove the sheets of paper from the feeder. Open the printer and remove the cartridges. Then unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper. Try to print again.
Apr 08, 2011 | Lexmark X3650 Printer
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Aug 30, 2010 | Brother DCP-7020 All-In-One Laser Printer
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
16 people viewed this question
old marine
old marine
