Question about Dometic Rooftop RV Air Conditioner
Hi could you supply details for our dometic rooftop a/c model cal 136.302 heating element o/l protection sensers part numbers and or availability source please
  • 68 Answers
SOURCE: btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
  • 59 Answers
SOURCE: How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Posted on Apr 21, 2010
motor1258
  • 6674 Answers
SOURCE: I have my dometic Rooftop AC unit. The
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
Posted on May 09, 2010
motor1258
  • 6674 Answers
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Posted on Jun 05, 2010
  • 1340 Answers
SOURCE: can mold accumulate inside rooftop
Mold could easily form inside.I am not familiar with the unit but if you call the/a dealer,they will usually tell you how to take the cover off free.If it is just clipped on they would know the best way for removal also.All I would do is start removing visible screws which appear to be holding on the cover.Clean the mold off with bleach/water mixture using very little bleach,clorox spray or something similar.Good luck! Greg
Posted on Aug 31, 2010
Dometic 610015.103 not heating
thermostat ,relay module, communication cable,or heating element issues
Sep 15, 2013 | Dometic Rooftop RV Air Conditioner
Camping world tells me the board is shorted out. It blows a 15 AMP fuse. Where can I buy another duo therm, comfort guard thermostat? They tell me the one I have is no longer available even tho My Motor...
Contact Dometic direct, with your model and serial number and ask them status on new control box, and if no longer available, what is replacement for it.
here's a link to customer support number and e-mails as well.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Contact/
Dec 08, 2011 | Dometic Rooftop RV Air Conditioner
I have a 15000 dometic airconditioner and would like to have a heat strip installed , where can I get the heat strip and instructons to install it?
You can get the heat strip at your local heating air distributer try looking for cc dickson company you will need the model number and serial number
Dec 11, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic RV airconditioner roof mounted, the model number shown on a tag inside the unit says it is Model CAL 136.312 Product Number 991650423, I cannot find this model in the Dometic catalogue is...
Your probably looking at the control module number or something in that area. When you have the ceiling assy off as in cleaning filters, look for a sticker directly on the base of the roof unit. Look all around on that base, even behind wiring harness, you should find a model number and serial number.
Jun 08, 2010 | Dometic Rooftop RV Air Conditioner
How can we tell if our dometic rooftop air conditioner/furnace has a heat strip or not.
Hi; If You have a heat pump then yes on heat strips. Does Your RV have a gas heater. If You gently remove the cover some times You can see the heat coils in the metal air flow tube...Also does the compressor run in heat mode ,if not then best guess You have heat strip capability...alpharome416
Feb 22, 2010 | Dometic Rooftop RV Air Conditioner
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Jul 23, 2008 | Dometic Rooftop RV Air Conditioner
Heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
May 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
51 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
