Question about Samsung HT-P38 System
We lost power and now when I try to turn it on "PROTECTION ON" appears and then it will turn off. Isn't there something I can do to fix this besides turning it on and off for an hour?
  • 345 Answers
Normally, that's exactly how you fix it but it may take more than a half an hour. Some devices take as long as 24 hours. If the unit doesn't reset itself after 24 hours, something is wrong and the the unit needs servicing.
That being said, your manual say that in case of a power outage to turn the unit off and hold the STOP (the little square) button on the unit for longer than five seconds. NOTE: Doing this will reset the unit and erase all saved settings.
Posted on May 28, 2011
My monster power outlet isn't giving me power, the
there is probably a reset button some where make sure that its pushed in good. sometimes if you dont push on it good you'll only reset one side only and all outlets work in pairs hot will not work without the nuetral. i hope this helps
Jan 25, 2013 | Audio Players & Recorders
Photoshop cs6 distorts color when open image in liquify
I had this same problem. It's something to do with PS using your graphics card to process liquify (and your card isn't suitable). Anyway, I discovered that going to Preferences and turning off the "Use Graphics Processor" option under "Performance" fixed it. I hope this helps.
Sep 23, 2012 | Adobe Photoshop CS6 for Windows - Full...
Kodak Easyshare z730 - possible problem flexible flat cable. I had a recent problem with a stuck power/mode dial turning too far past the video mode. I was successful in carefully opening the camera and...
It's obviously a switch problem, not a ribbon (which controls the lcd screen) problem. Start doing your research to find that "perfect" camera. Read all the reviews to see what actual owners think in addition to the experts. Or......you can "limp along" until you get tired of that.
Oct 05, 2011 | Kodak EasyShare Z730 Digital Camera
Our stereo system suddenly powered off, the timer light on the pioneer xv ev7 is blinking but it doesn't turn on, what should we do?
Hi, If this isn't a "Timer" problem, meaning check your manual to see that the Timer hasn't been invoked and turn it off if possible, otherwise this usually indicates that the power supply has failed, that or there is a fault that has caused the protection circuitry has been tripped.
The very best thing to do is to contact the manufacturer, and ask them for a referral to an authorised service center, and then ask them when face to face only for a "Quote" first, and go from there. This way you can make up your mind as to repair or replace?
Sep 10, 2011 | Audio Players & Recorders
This isn't the latest macbook air, but its problem is that when I turn it on after a while after the apple logo appears, a message pops up saying, "You need to restart your computer. Hold down the...
This means your MAC is having a kernal panic, which could be caused by a failed update, a driver or program that is incompatible. You may need to start your MAC with your system cd/dvd and run the disk checker to repair hard drive errors and file permission errors.
I'm not sure what OSX version you are running but you could also try the steps outlined in this apple knowledge base:http://docs.info.apple.com/article.html?path=Mac/10.5/en/8965.html
If this does nothing, you will need to take it into a apple store for servicing, or reinstall the OS (you may loose your programs and data depending on how your reinstall)
Chris
Sep 08, 2011 | Apple MacBook Air
It turns on only when I remove and insert the batteries. Now appears Line 1111 Emulator. Does this calc have salvation?
That sounds pretty bad.... you can try to take out all batteries, including the back up, leave it sit for a minute or so. If that doesn't fix your problem you can try calling TI-cares (800-842-2737), they may be able to help. I hope it isn't lost
Aug 02, 2011 | Texas Instruments TI-89 Calculator
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
Lost sound suddenly. It seems that the power supply was gone.
What signs of life DOES it have?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 01, 2011 | Denon AVR-1609 Receiver
Vizio L42, wont turn on
Usually when this happens, the TV is in Protection Mode. When the TV detects something has gone wrong inside, the TV will prevent itself from turning ON.
Try leaving the TV unplugged for 30 -45 minutes so the TV can discharge and reset itself. If this doesn't fix the problem, most likely it's a power supply board related issue. At that point, you may want to get a price quote from a local TV repair shop. The cost of fixing the TV may exceed the price of a brand new TV.
Aug 06, 2009 | Vizio L32 32 in. LCD HDTV
Samsung HT-P38 System Logo
190 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
