My Intertherm G5RC080C-16 unit is not draining properly. I pulled the visible hoses and found no obstructions in the hoses - and it was dry as dust where they connected back to the 1. blower and 2. bottom and back of what I would guess is a collection area. The sump pump was full and not working so I cleaned it and it works like a charm now, but no water is going into it, only all over my basement floor. Where can I look to open up the water flow back to the pump>
  • Heating & Co... Master
  • 1,711 Answers
Sounds like a dirty coil and filter. The system is starving for air therefore pulling air back through the drain hole preventing drainage.
Posted on Jun 10, 2017
  • 6 Answers
SOURCE: Goodman AWUF 3 ton fan coil unit
The evaporator is probably not excessively condensing in as much as the amount of condensate is directly proportional to the amount of humidity in the air. It sounds like the problem is more likely the primary drain is restricted by algae; if this is the case I suggest pouring a cup of bleach in the primary drain and see if that clears the primary drain. Note: the secondary is just that it is designed to keep the water from overflowing into the house. Hope this helps!
Posted on Oct 05, 2008
  • 417 Answers
SOURCE: Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Posted on Oct 17, 2008
pierre1811
  • 144 Answers
SOURCE: Where do the filters go on the Intertherm MGH055AB?
The filters on an Intertherm usually go on the inside of the front panel
Posted on Mar 06, 2009
SOURCE: dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Posted on Jun 10, 2009
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
Bosch Classixx Fridge freezer KGU30604 I keep finding water in the bottom of the fridge but whenever I clear it, it reappears. Both fridge and freezer appear to be working otherwise. The fridge is set to ...
Hi Kloynes,
It could be a problem of LEAKAGE.....Followings steps may help you tackle the problem:
Steps
  1. Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
  2. Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Tips
  • Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
Warnings
  • Use caution with anti-bacterial products. Make sure that any such products cannot flow back into the food compartment.
Things You'll Need
  • Wire hanger
  • Anti-microbial agent such as chlorine bleach, rubbing alcohol or anti-bacterial soap.
Thanks
Sep 03, 2008 | Bosch Refrigerators
My Neptune washing machine is not draining. There is no kink in the hose, and I have tried resetting the circuit breaker panel. I also tried putting it in different cycles. Alas, no draining is...
you can use a wet dry shop vac and attach it to the end of the drain hose to remove any water in the unit.Then you need to remove all the hoses to the drain pump and look for any obstructions in the hose or the pump itself.also check and make sure the wiring is in good shape and connected properly if there is no obstruction the n you may need to replace the drain pump
Sep 08, 2010 | Maytag Washing Machines
Refrigerator is leaking from the bottom
Good luck........
Aug 01, 2010 | Jenn-Air JCD2295HES Side by Side...
Ice maker is le
Good luck......
Aug 01, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
How do you unclog the drain from the air handler (intertherm)? It's draining into one of our bedrooms instead of outside.
Two possible solutions, one would to hook up a wet/dry vac to the condensate hose where it discharges and give it a few minutes to do it's job. The second and messy way would to blow into the condensate hose to clear the obstruction.
Jun 11, 2010 | Heating & Cooling
MY LG WASHING MACHINE SCREEN KEEPS ON SAYING OE
It is a long drain error and appears when the washer is not fully drained after 10 minutes of draining. It can be due to a clogged or kinked drain hose, clogged pump filter, or the pump is not working properly.
LG Front Load Washers Drain Problem Troubleshooting and Repair Guide
  1. Remove the two screws on the back of the top panel securing it to the cabinet.
  2. Slide the top panel to the back of the machine then lift it.
  3. Disconnect the wiring harness connector from the control panel.
  4. Pull the dispenser drawer out and remove the two screws under it.
  5. Lift the left side of the control panel and pull it out.
  6. Remove the four screws holding the top part of the front panel to the cabinet.
  7. Open the pump filter cover and remove the screw holding it.
  8. Insert a flat-bladed screwdriver or a putty knife in the left and right edges of the filter cover then pull it out.
  9. Remove the screw from where the pump filter cover is removed.
  10. Open the door and remove the door gasket retaining hoop by stretching the retainer spring.
  11. Peel off the door gasket into the drum.
  12. Tilt the front panel and remove the door switch wiring harness connector.
  13. Lift and remove the front panel from the cabinet.
  14. Remove the sump drain plug and drain the water in the sump into a shallow pan.
  15. Remove the sump hose from the tub by loosening the clamp holding it.
  16. Remove the drain hose from the drain pump and the recirculation hose from the recirculation pump if there's any.
  17. Remove the two screws holding the pump assembly to the cabinet.
  18. Push the pump assembly in and lift it out of the machine.
  19. Remove the pump filter from the pump housing and check it for any obstruction.
  20. Check the sump and drain hoses for any obstruction.
  21. Remove the drain pump from the housing and check the impeller for any obstruction or damage.
  22. Replace the drain pump if the impeller is damaged or if no obvious obstruction is found in the pump filter, sump hose, or drain hose.
  23. Install the new drain pump and reassemble the other parts in reverse of the disassembly steps above.
Please let me know if you need further assistance regarding this problem.
Jan 23, 2010 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Jun 03, 2008 | Washing Machines
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Drain Problem
The first thing you need to try is to pull a vacuum on the drain hose to see if you can pull water from the tub. You can do this by using a wet/dry shop vac and connecting it to the end of the drain hose. If the water drains from the washer you may not have a clog. It may actually be a bad drain pump. If water does not flow, or is draining slowly you will need to check the drain pump AND the hose between the pump and wash tub. You can accomplish this by removing the lower kick panel under the door. There are three 7mm screws under the bottom edge. The drain pump is located on the right hand side of the machine or directly in front under the wash tub. It is the ONLY pump in the washer so it should be easy to find. There is a clean-out access that you can remove to clean out the pump impeller. Removing this access will cause whatever water is remaining in the tub and drain lines to come gushing out. That's why it is important to try to remove as much water as you can, FIRST. Even if draining the tub with a vacuum is slow, let it drain. When removing the drain access, look for anything that may be obstructing the impeller. I have found items as small as a Q-tip can stop the pump (believe it or not). In a nut shell: Pull a vacuum on the drain hose - 1. WATER DRAINS EASILY - failed drain pump or obstructed impeller. 2. WATER DRAINS SLOW - Obstructed drain pump and/or drain line. 3. WATER DOES NOT DRAIN - Serious obstruction somewhere in the drain line BEFORE the pump (usually a sock or wash cloth that has worked it's way between the basket and wash tub). *You will notice the drain hoses collapsing as you pull a vacuum if there is a serious clog. Let me know if this helps you.
Aug 17, 2007 | Kenmore Elite 45986 Front Load Washer
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
