Question about Dishwashers
Disposal plugged up and water backed up into dishwasher. Cleared disposal and dishwasher drain line. Checked around sump but dishwasher won't pump out. Sounds like pump is trying to run. I can blow air through the drain hose from the disposal and get bubbles in the water. Turned off breaker for 1 min. then tried reset. Can hear pump humming.
  • cricket_king May 28, 2011
    Thank you. Can I access the pump from inside the unit by removing the wash arm or do I have to pull the entire unit and access from underneath? If inside how does the wash arm come off?
  • cricket_king May 30, 2011
    Followed instructions. Found shredded banana fiber in drain pump. Cleaned out and bench tested. Worked fine. Put everything back together and it works but is leaking off the face of the housing where it enters the sump. I think I tightened everything properly. Am I missing something in the way of washers, o-rings, etc or just sloppy reassembly? It sounded like it pumped the machine dry but is still leaking several drops per minute after a couple of hours. Where would this water come from? The sump still has some water in it or the drain hose has water in it due to the elevation to the disposer?
    Thanks.
  • 1,998 Answers
The pump is humming because its still trying to get all the water out of the unit. Deinstall the dishwasher and pull the entire dishwasher out from under your cabinet. Next step would be to disconnect the drain line from the drain pump and check to assure that there are no obstructions in the line itself to where it connects to the pump if the entire line is free from all obstructions you next step would be to remove the drain pump itself from the unit and assure that not only the impellar is spining inside the drain pump but also that there is no foreign debris stuck inside the pump as well. also before pulling the dishwasher out reassure that there is nothing blocking the drain line to where it goes into the disposal if the drain line is cleared and the pump is cleared you can also bench test the drain pump by taking a extension cord and cutting off the female end of the cord and adding two electrical c-clip connectors to the cord this some call a powered jumper or a suicide wire it allows you to test the drain pump outside of the machine in order for you to see if the impellar is actually moving if you have any further questions message me back I await your reply Thanks Rick
Posted on May 28, 2011
  • Rick Ead
    Rick Ead May 30, 2011
    One of the first things you do when diagnosing an issue is LOOK very well is the water coming from around the sump area then most likely you did not seat the sump properly if you removed it there is a rubber oring that the sump sits down into and the sump sits in only one postion and then you use those plastic clips to lock it in. In order to find where your unit is now leaking you need to get down there and observe where your leaks are coming from and why you have them I think that the sump you did not postion properly and you may want to take it back out I usually use someone else to push down on the sump while i hook those plastic clips that hold it in place if the sump goes in on an angel it will leak for sure If you have any further questions message me back I await your reply Thanks again Rick
  • Dishwashers Master
  • 1,902 Answers
Hello & Welcome to FixYa
You will have to take the drain pump assembly apart and clean it completely, after this if the problem is not solved then the pump motor is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 27, 2011
  • Kevin White
    Kevin White May 28, 2011
    Check this video:
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter.
Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.
In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem.
For more troubleshooting tips and solutions, see Dishwasher not draining. I hope this helps!
Sep 27, 2012 | Kenmore 665
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
Replaced disposal and now dishwasher isnt draining
It sounds like you've done everything fine. I would disconnect the dishwasher drain line from the disposal, have a bucket ready and see if it will drain. It's possible that there is a plug or something else left in the disposal opening that is blocking the water. If the dishwasher won't drain with the hose off of the disposal, there is a problem with the dishwasher that has nothing to do with your disposal installation. Hope this helps and good luck!
Mar 12, 2010 | Dishwashers
Dishwasher won't drain
remve the drain line connected to the garbage disposal take a flat blade screwdriver insert it into the garbage disposal and hit the end of the screwdriver , the plug will pop out
to verify after hitting it stick the screwdriver back in if it has not removed the plug do it again
Apr 04, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
Owen Barnes
