Firmware problem - Audio Players & Recorders
  • 345 Answers
Go to the manufacturer's website and download the latest firmware. With so little information provided it's very difficult to give a more detailed answer.
Posted on May 28, 2011
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
How do i download missing firmware for ubuntu
Loading Missing Firmware As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
note.png Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
warning.png Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the firmware (package) is installed manually.
note.png If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
Jul 17, 2012 | Computers & Internet
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
I need to know the modem login and password for level1 modems
Levelone - FBR-1161A (Levelone Firmware) admin admin Levelone - FBR-1418TX (Levelone Firmware)
admin Levelone - WBR-3405TX (Levelone Firmware) admin admin Levelone - WBR-3406TX (Levelone Firmware) admin admin Levelone - WBR-3408 (Levelone Firmware) admin
Levelone - WBR-3800 (Levelone Firmware)
password Levelone - WBR-6000 (Levelone Firmware) admin password Levelone - WBR-6001 (Levelone Firmware)
password
Dec 10, 2010 | Levelone ADSL2+ Modem Router FBR1161A
I have a netgear WNR1000 and my xbox live doesnt work
Using Xbox Live with NETGEAR Routers Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); NETGEAR has Xbox certified routers!
Note that the listed, certified firmware may no longer be available; later firmware is likely to work, but is not certified unless listed.
There is no information on what will be certified in the future. But if an existing model does not appear on the product dropdown on NETGEAR Home Page, then it will not be certified.
Nov 11, 2010 | NetGear WNR1000 Router
I need to update the Belkin Router for Wildblue.net
Contact Belkin Tech Support At Toll Free Number- 1-800-585-2494
Apr 22, 2010 | Belkin F5D8236-4 Router
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
 Grubhead
Grubhead
