Question about Microwave Ovens
Replace handle on Kitchen Aid Microwave hood Comination Molel KHMS155LSS1
  • 710 Answers
Hi phillips744,
You can get the handle and screws from searspartsdirect.com.
I have the exact page for your model here: >>>> http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS1/0593/0123370/W0312084/00002?blt=06&prst=0&shdMod=KHMS155LSS1
Copy and paste the entire address, between the arrows, into your address bar on your browser. The page with your parts on it will open up. The handle is #7 and the screws are #8. Just click on them and you can order the parts.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 28, 2011
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
Jan 23, 2012 | Microwave Ovens
Replace door handle, kitchen aid microwave, model KHMS155LSS3
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Dec 16, 2011 | Microwave Ovens
I need. To replace the handle for a kitchen aid microwave. I have the new part but it came with no instructions. I am afraid to do to break the microwave model# KHMS155L 0. Any one who knows where to...
Here's an exploded view of the door:
Item 10, the door panel, just snaps over the rest of the assembly. If you work slowly and carefully with a flat object like a putty knife, you can separate the door panel and take it off without damage. This will expose the screws (number 8) which hold the handle on. Then you just need to snap the door panel back into replace after you put on the new handle.
Good luck and thanks for using Fixya!
May 15, 2011 | KitchenAid Microwave Ovens
Kitchen aid khms147hss0 microwave - handle broke and gray plastic ( has 3 screws) on perimeter of door itself cracked - was going to replace complete door - how do you replace the complete door - remove...
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchen aid stainless microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 14, 2008 | Microwave Ovens
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Khms155lss1
The handle can only be changed by separating the outer and inner shells of the door. You can pull the outer shell off the inner shell by removing the three screws at the end of the door and then using firm force to pull the shells apart. It helps to gently pry along the bottom, top and inside (nearest the hinges) with a thin flathead screwdriver or other very thin metal object. You don't have to get it all the way loose; just a little is fine. You can then use the two clasps on the back of the door (that hold it shut when it's closed) to pull with. I found that inserting a slim screwdriver into the lower clasp and using that as a handle (not a lever!) gives you a better grip. Hold the outer shell of the door with your left hand while pulling the inner shell in the opposite direction. Be carefull not to twist or bend the clasps; they are plastic and will break. The shells will pull apart and then you can access the screws that hold the handle. Change the handle then press the door shells back together. Make sure they are snug all around. Replace the three end screws and you're done.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
