Question about Sport & Outdoor - Others
I have a pr173y22rp poulan pro i purchased last summer. it worked fine last summer. this summer it will start, then stop on its own and the bag is not full
#1 Taper
  • 1040 Answers
SOURCE: my 2 cycle poulan pro weed eater won't start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see day light through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 4088 Answers
SOURCE: I have a Poulan Pro
Take the machine back to where you got it and let them fix or replace it. You need to see a running mower before accepting. Good luck!
Posted on Sep 12, 2010
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
Posted on Sep 17, 2010
SOURCE: Bought unit new last summer.
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Posted on Oct 13, 2010
  • 2239 Answers
SOURCE: My Poulan Pro 295 chain
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Posted on Apr 25, 2011
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
Poulan 16" saw, start fine, runs fine until it
A couple of ideas, it could be a fuel tank breather issue, when it starts to die just try loosening the fuel cap, if the saw picks up again you will need to change the breather, the only other thing i can think of is a bad ignition that is breaking down when hot, the only aswer to this is to replace the ignition unit
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a Poulan Pro self-propelled lawn mower pr173y22rp...It will not start. It has never started and it is brand new! What do i do?
Sep 12, 2010 | Poulan Garden
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Does poulan make anything last longer than 1 summers use or is that how they stay in buisness?
no there stuff sucks. you want quality buy husqvarna.i had a poulan chain saw lasted a yr and half then stopped working.
Mar 23, 2010 | Poulan Featherlite Gas Blower, with Low...
Poulan Pro model 185H42ST dies after 30-45 minutes mowing
Put a carb kit in it. If that does not work replace the gas cap they are supposed to breath and if they get clogged it will create a vacuum in the tank starving the engine for fuel.
Apr 24, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro 260 42cc. Need a manual.
For parts manual
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Hi and low speed jets are both 1 1/2 turns open, fine tune from there.
Apr 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Sport & Outdoor - Others Logo
66 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
