Question about Maytag MDC4650AWB 24 in Builtin Dishwasher
Start button won't work. All other buttons still light up.
  • 5380 Answers
SOURCE: Won't start/run. CLEAN light blinks
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Posted on Jun 20, 2011
  • 3247 Answers
SOURCE: unit just quit. won't start
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
Posted on Jun 23, 2011
  • 3247 Answers
SOURCE: I can't get the control panel to reset. The
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Posted on Jun 24, 2011
Daniel S
  • 4323 Answers
SOURCE: buttons won't work at all. can't turn it on.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 11, 2011
superese
SOURCE: maytag dishwasher won't start but other buttons work
It's probably your Circuit Board (CB)! My dishwasher is on the second CB and it keeps blowing the dispenser transistor. This needs to be brought up to the MAYTAG goons to see if they will start recalling this crappy thing. My machine is barely a year old and will have it's third CB!
Posted on Oct 10, 2012
Start button won't ignight
Do you have power on the bike, do the lights work, horn work, does the battery have a good charge.
Jun 07, 2013 | Triumph Motorcycles
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
2008 Lexus ES350 won't start after multiple times
You will need the dealer to look at his, diagnosis of this problem takes special equipment and skills.
Oct 22, 2012 | Cars & Trucks
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I changed the key batteries for my 1999 BMW 323i after they died. Afterwards the remote unlock and lock won't work, the car also won't start but it can turn over/on and the radio and the lights...
stick the key in the ignition, turn it to the on position, remove it within 5 seconds, then hold the unlock button down and press the lock button 3 times within 10 seconds and release both buttons. The doors should lock/unlock to give you confirmation and your key should work.
Jul 05, 2011 | 1999 BMW 323 Series
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Maytag MDC4650AWB 24 in Builtin Dishwasher Logo
29 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
