My washer will not stay locked. I just bought a new safety lock part from fridgidaire but I cannot figure out how to access the lock on the washer to change it. If I could figure out how to take or peel back the grey plastic ring/boot I could get to it but I can't get to it without using a knife! Please help! Thanks
  • Jules7887 May 28, 2011
    It was perfect! Thank you so much!
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
You can view this video for door lock replacement:
Please get back to me if you have any other questions.
Kevin
Posted on May 27, 2011
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Dec 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
I can't open the door to the washer, asko 10505. I ran a load, and it's all done washing, but now the door is clicked shut, and I can't figure out how to release it and get the laundry out. can you...
After teh program the latch had to disable but possible that the lock got jammed or the end link is not connecting.
Look from the bottom and you can access the lock section to release and get the lock function.
Once it opens use good degreasing spray and then oil then lock as there can be rust or dirt that has got it stuck.
The end program safety link must also work.
Sep 02, 2010 | Asko W6021 Front Load Washer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool duet dryer is stuck on control lock mode. Have tried pressing the end of cycle button for several seconds and control lock button stays on....dryer won't run.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#!#!
Jun 27, 2010 | Whirlpool GEW9250 Electric Dryer
My front loader door wont lock
Believe it or not, you may be able to fix that yourself with some spray lubricant applied to the shaft of the electric lock mechanism, but you will have to remove the lock to lube where it's stuck. Then you will need to work the locking jaw back and forth till it breaks free then reinstall.
Mar 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Hi, i have a fridgidaire ftf214ofs washer that wont start and the door lock light stays on when i try to start a cycle, could you offer some advice?
I would have to say it sounds like the door latch or the safety switch for the door is out of adjustment or the door got bent
Jan 31, 2010 | Washing Machines
My kenmore elite washing machine has all the lights on but will not pause or start or anything with or without the door closed. should I just unplug the washing machine and plug it back in like a computer?
couldn't hurt to try it! could be the safety interlock that latches the door. on mine, there's a certain 'grace' period that allows adding more clothing before the water reaches a certain level. then the latch locks! stays locked until the load is done. mine's a fridgidaire. so, different.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
I have a whirlpool duet washer. It worked fine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fridgidaire front load washer..control lock won't shut off
I spent two days freaking out about this same problem.
I almost went out and bought a new machine because repair technician would cost so much...
The solution of pressing option and select at the same time didn't work right away...but after 2 minutes ... it did !!!!!!!!!!
Awesome. Thank you thank you to the person who posted that solution!! It actually worked!
Nov 14, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
