Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Big EZ filter doesn't just push in but screws in. There is a component that has an associated component with a hex rod in it, but I don't know if these go over the filter intake threaded pipe and simply recieves the filter, but the filter is not secure when I try this? What is the proper way to mount the filter?
How do i remove bathroom sink drain plug?
Usually, that only works with tub drains. Look under the sink, at the drain pipe, about 3 inches below the bottom of sink. On the back side (away from the door) you should see a knurled nut with a metal rod coming from it. unscrew the nut, then pull the metal ball/rod combo out. This will release the drain plug. To reassemble, fiddle with it until you get the rod through the hole in drain stem, then push ball into it's socket, and replace knurled nut. Tighten enough that it doesn't leak, but not much tighter than that, or you'll lock up the drain plug and have to loosen it a bit.
Jan 12, 2018 | American Standard Plumbing
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
2003 kia frount axle removal
Jack up car use jack stands remove wheel. Get a 3/4 breaker bar and a socket to fit nut on front wheel remove cotter pin remove nut. Loosen nut before jacking up Undo nut on lower ball joint and tie rod. Push down on tie rod hit housing with big hammer it should come right off. Now pry down on the frame holding ball joint and hit the housing with a big hammer it should break loose if it doesn't rent a tool at auto parts store. Pull strut assembly away from axle and pull axle out. When you put new one in push till you here it snap in.
Dec 16, 2011 | Nissan X Cars & Trucks
Diagram for timing belt and timing marks
Below are some pictures for you. I will give you a hint incase you don't know. If you look at the botom picture, it shows you the tensioner. You will want to push the rod until you can put the hex wrench through the hole to hold the rod. Then install the dust cover. When put the tensioner back on you will want to alternate back and forth on the 2 bolts so it's good and even and then remove the hex wrench. Hope this helps and good luck.
Dec 10, 2011 | 1999 Lexus ES 300
I borrowed my friend's Dremel to cut a few screws...originally she had the EZ Lock Cutting Wheel but it is too big so the smallest they make is not with the EZ Lock head so I was told to get Dremel 420...
I don't know what the numbers are, but the little abrasive cut-off wheels are held on with a mandrel type bit and a screw. Make sure you get the right size wheel and the right size mandrel, they make a couple different sizes, you can't fit the small wheels on the bigger screw. Anyway, I use my cut-off wheels all the time, usually to get stubborn screws out by cutting a slot in the head and turning it out with a flat blade screw driver. The wheels will cut anything, most people scoff when I say that, but it is true, they will cut anything.
Jul 15, 2011 | Dremel Garden
1st time ever using a compressor. Need to disconnect the yellow hose from machine to move. I've pushed down on the bronze ring with texture, and then it's loose but not out. Don't want to...
It sounds like you are trying to disconnect a quick-connect fitting. Don't loosen the hex. No tools required. Just pull back a bit harder on the outer brass ring then pull out the male end of the fitting. You might have to push it, then pull it. A word of caution- if the male end is on a hose that has air pressure in it, it's going to very rapidly escape from the hose. If you aren't prepared for that it will startle you and you could hurt yourself. Just hold on to it securely and don't put your face too close. Good luck, Al K
Jun 21, 2011 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
#3&4 cyl. Have spark and fuel but air idle screws don't do anything. When warming up backfired out exhaust and carbs
Check the valve lash-sounds like valves are tight in those cylinders. Idle air screws won't do anything if the valves are tight, the motor doesn't develop vacuum when the cylinder doesn't seal. And without vacuum, carbs don't work. If the valve lash is within specs, run a compression test, most "rockets" run a minimum PSI of 150 to be within spec. Good luck!
Jun 11, 2011 | Suzuki GV 1400 Cavalcade LXE Motorcycles
My Susiki dies sometimes when I make a stop or slow dow suddently. Whats the problem?
I would start with the easy less expensive stuff first.
Check/Replace your spark plugs. Carbon fouled, sooty plugs don't like to idle.
Clean/Change your airfilter. Dirty air filters choke the motor. choked motors either stall or rev high.
Carburetor idle screw needs set.
that is adjusted after the bike is warmed up to operating temperature, then set idle.
If that doesn't have you cleared up then you'll need to have your carbs cleaned.
Have a great weekend
Big Al
May 21, 2011 | 2000 Suzuki VZ 800 Marauder
The inside door knob came off of the Kwikset keyed door lock. How do I re-attach the knob?
There is probably a small set screw (hex head) on the bottom of the knob. If that doesn't work try just pushing it back on.
Feb 24, 2011 | Hardware & Accessories
Haier HLP21E belt broke. My machine was overloaded. How do I replace it?
put new belt on big pulley first then roll in over on smaller one
Mar 29, 2010 | Haier HLP21E Top Load Washer
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
Craig Butler
Craig Butler
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
