Question about ASUS M2N-MX Motherboard
USB 2.0 PCI ADAPTOR 4 PORT 1PARA. TO #4
THE 1 INTUR. PORT TO FRONT PANNEL. I MADE A SHORT CABLE AND RECEPTICAL TO THE FRONT. WHEN I CONNECT MY DATA TRAV. TO IT ,IT IS NOT RECONIZED BUT WHEN I PLUG IT INTO THE PORT ON THE ADAPTOR IT IS, THE WIREING CHECKS OUT OK. CAN YOU HELP? AL BROWN THANKYOU INADVANCE
    Sergeant:
  • 300 Answers
Pleasure to see a fellow brown are we related ? :->
have you performed a test of each wire with a multi meter
to determine if each wire is indeed not broken ( open circuit )
if things check out ok with the multi meter , then it's time to start
digging deeper , such as asking yourself if you have indeed ENABLED the usb header at the bios level and has an IRQ that
does not conflict with other devices.
Also you'll want to make sure a driver is properly loaded for each
USB port , sometimes we forget to do all these things.
if all checks out after that , it's time to start getting suspicious
of the device being plugged in to the port , a dirty port can mean loss of connection , silly but so true.
if all checks out after that but still no luck , it's time to start asking yourself if you want to test things farther with extensive
checking of each USB port to make certan each port can read and write , this can be done with certan software.
if everything checks out at that point but still no luck ,
it's time to start asking yourself if you've made a boo boo
by loading an incorrect Operating system, ( rare )
I hope this information has been helpful , sometimes
we fail to get our trouble shooting ducks in a row.
shalom
Posted on Aug 26, 2008
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
Find the correct connections on motherboard for usb ports
frist you have some port of usb on front pannel of cpu . connect the wire of usb . u can plug the usb card from on board pci slot then you need to enable your usb in bios
Apr 10, 2010 | EliteGroup K7S5A Pro Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Jan 22, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I am having problems at times, connecting on the internet, and other networks online. (i.e.)an icon would appear and suggest an error/data was made and being reported, and automatically swicth me back to...
Cable has changed it's policy and standards many times in the past
if you have a cable modem you will most certanly need to decide
if you're going to be using the cat5 ethernet connection or the USB connection cable
if you have an onboard ethernet adaptor or a PCI ethernet adaptor
it's best if you use the cat5 connection of the cable modem
if you have no ethernet adaptor , you will need to use the USB connection of the cable modem
and connect that to your computer , which will most deffinately require that you have working
USB ports and at least service pack 2 loaded to enable USB 2.0 , and a driver from the cable
modems driver CD
if you're using a router , use the cat5 connection of the cable modem
( make sure you contact your ISP to walk you through the setup proceedures )
Az Selah ..
Sep 17, 2008 | Computers & Internet
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Can't connect psp component cables to tv
okay. here's what you need to remember as i encountered the same issue and had it resolved.
1. connect the psp tv out component cable to the tv. make sure you have every cable in their correct plug-ins.
2. on your tv remote, press output until your tv displays the correct output data info. it will display component 1 or component 2. make sure this aligned with where you connected your component cable.
3. turn on the on the psp, then press and hold the display button ( it is near the start and select buttons on your psp, with a box like icon. after 5 seconds, it will give you a gray screen with a box icon and an arrow which means you are transferring the data out from the psp to your tv display.
4. enjoy your psp on tv!
Aug 08, 2008 | Video Game Consoles & Games
Trying to set up front usb ports on asus p4p800se
Find usb pin in the boad " USB1 & USB 2" You can see five pins in the board composed of two lines. connect the cable in the line composed of four pins. from left. VCC, Data-2 , Data+2, grnd2. After connecting try a Usb mouse if the USB mouse function well then connection is correct.
Jan 06, 2008 | ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA)...
ASUS M2N-MX Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
