My Electrolux ewt806 has error code ld. Lid is closed and machine still wont work.
2 Suggested Answers
  • 51 Answers
SOURCE: My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Posted on Jun 12, 2009
Electrolux EWT806 - PU Error Code
Pu is short for pump. You say you checked the motor and filter, but is the motor actually running when it should? If it is, you can hear it. If not, there may be a problem where the pump is not receiving power. Armchair troubleshooting isn't the same as actually being there. Keep hunting and you will find the cause.
Jan 11, 2015 | Electrolux Washing Machines
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
LD error
LD is long drain time. Be sure there is no blockage in the drain line and clear the filter if there is one. What is the model number of the unit?
Nov 28, 2012 | Westinghouse Washing Machines
Model wtw6500ww1, error code LD, power off power on selected cycle but wont start just blinks and locks all buttons. let it sit and then error code comes back. washer is empty but wont reset to start...
Suspect that stands for LiD. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Fault code EF electrolux EWT806 what is the problem
So we just fixed our EWT806 after it suffering the dreaded EF fault... The problem... Too higher mains voltage coming into the house! Albiet within specification from the supplier, the Electrolux EWT806 doesn't like anything around 250 volts! Obviously a poor design on the control board which is unable to accept a wide supply voltage!
Solution, isolation transformer inline with the machine. Now it runs like a dream!
Jul 31, 2011 | Electrolux Washing Machines
My whirlpool cabrio is beeping and displaying ld, what does that mean
I do not have a complete list of Whirlpool error codes but 'ld' probably stands for Lid (Error) .There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest ;-0(
Alternatively it could stand for LoaD error- but you are likely to have refered to problems of unbalanced loads in your posting I suspect!
John C
Jul 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Water is draining but doesn't drain the lower basin. shows ob, sl, or ld on readout. Have to unhook drain hose - let it drain then it will usually start working properly.. when the basin is full and it...
Hi There
I'm giving you the coeds that you need. So i hope this helps you and let me know how it goes.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Press STOP/CANCEL to clear the display. S Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Jun 11, 2009 | Electrolux Washing Machines
Washing machine
replace the lid switch
Feb 24, 2008 | Washing Machines
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
