Question about Samsung ST600 Digital Camera
I have samsung ST60 I used it and then put it away for about 2 weeks, next time I switched the power on the screen says system error 251, 402db978, 00000230. The lense comes out and then it freezes in that position and can do nothing with it. I put it on charge but that was no help. Serena
jonags3
  • 83 Answers
SOURCE: put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Thanks.
jonags
Posted on Dec 14, 2008
SOURCE: my samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Posted on Feb 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: samsung pl50 lense jammed?
Hi
Thanks for using FixYa. Please check the battery is fully charged.
If you are able to access the Menu, please select Initialize under Settings and Main Settings 1 Menu and press OK. If still the issue persists, perform the power reset by removing the Battery and pressing the power button continuously for one minute. Then, leave the power button and reinsert the Battery.
To reset the Digital Camera by using a RESET button follow these steps---
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
To perform a manual power reset follows these steps---
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If still the issue persists then it means that the cabinet is opened or LCD cable is touched which is caused by connection defect or poor contact between connector and LCD cable due to the pressure by the rib in the front cabinet to the connector. If still its not resolved then as its a new one so you should use its warranty and get it replaced just to avoid future issues.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 05, 2010
  • 11967 Answers
SOURCE: Samsung L313 camera - lense is not retracting when off &...
You could return it (recommended) or try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 07, 2010
  • 11967 Answers
SOURCE: samsung didgital camera lense keeps will not
Posted on Mar 27, 2010
How to fix Error F3-f200-0002 on toshiba windows 7 laptop with recovery media on flash drive
If you still have your recovery partition that the computer came with you can do this:
1. Initially you keep hold the power button for around 5 to 10 seconds to turn off your system. Keep in mind that keep holding the power button force the system to turn off. But any of the unsaved data will be lost.
2. At the similar time press and keep hold the zero key simultaneously, now push the power button one time to switch on your system.
3. While the screen is get appeared then free the 0 key.
4. If it any message to select the 32bit or 64bit operating system then you click Next button.
5. When provoked by the warning screen; click on to the Yes button to keep continue with the system recovery.
6. In that choose Recovery of Factory Default Software from the menu and then hit it off on the Next.
7. Choose Recover to out-of-box state option from certain options and then click Next button once again.
8. Understand and recognize this final warning screen.
9. Now finally click Next to start recovery
Aug 31, 2015 | Toshiba Computers & Internet
Error flashing on screen
switch off your stuff and unplug all the power cord so that all setting go back to previous state.
after 10 or 15 minutes plug all the power supply and switch on.
If same happen, notify me again.
Dec 28, 2007 | Philips HTS3450 System
To recover password to unlock screen
Samsung Galaxy Tab Hard Reset GT-S6102
1.press upper voume button + menu + power button
2. rebbooting screen will appear with options like android system recovery, android system recovery rebbot system, apply update from sdcar, wipe data/factory reset, wipe cache partition...
3. choose "wipe data/factory reset" option
4. select yes and delete all.... select options through volume key
5. press rebbot now
6. handset formatted and back to normal state
7. successfully done
Jan 10, 2014 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
RFG298HDRS/XAA error code 33 E FRIG SEEMS TO WORK FINE CONTROL PANEL IS NON RESPONSIVE TO INPUT
E-33 The initial value of HEX is under "14" for 30 seconds while
a weight sensor in operation.
Nov 27, 2012 | Samsung RFG298HDRS 29 cu. ft. French Door...
Samsung 4828fn wont print message - system error - cycle power
All SCX-4828 and SCX-4826 buyers should launch a class action lawsuit against Samsung. I have TWO identical SCX-4826 printers, purchased at the same time. BOTH developed "System Error, Cycle Power" errors within a few weeks of each other! I suspect this is a programmed "error", not that something is "worn out" but rather it is in the programming of this series of printers. In other words, I believe they are "designed" to break after a certain length of time (in my case, just over 2 years of use - how convenient for them, just out of an extended warranty). I called a Samsung repair shop and was told that it was a "Fuser" problem. How could 2 printers develop an identical problem within weeks of each other? Coincidence? I think not!
Jun 30, 2011 | Samsung SCX-4828FN All-In-One Laser...
Error ink system has failed,error 0xc18a0401. this
Please follow the below steps and the issue will be fixed. STEP 1. 1. Un plug the power chord from the back of the printer. 2. Press and hold the power button of the printer.Wait for 30 seconds. 3. While holding the power button, re-plug the power cable. 4. Turn on the printer, if it is not on. STEP 2. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) 2. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen 3. Press and release the ?OK? button. 4. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 5. Press and release the ?OK? button. 6. Display should say ?Hardware failure status: Clear. Press OK to clear?. 7. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 8. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 11. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. 12. If the printer has already initialized, then go to the next step. If not, the printer will start the ?ONE TIME INK INITIALI-ZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation. Please come again and give the vote if the issue is fixed as it will really motovate me to help people.
May 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have 2 monitors connected to 1 computer using a
satservice, What happens AFTER 15 min of FLASHING?? What did unit do or act like 3-4 weeks ago? Is the screen both BLACK and BLANK? or is screen just black and you can SEE win-desktop if you shine a bright flashlight 1 inch from screen at differnt angles? Can you use your Samsung warranty? Will monitor do same when connected to different KNOWN GOOD prebooted to desktop PC? Are you refering to the "power ON" indicator light on front BEZEL as the FLASHING thing? Need more info, but I suspect "shutdown of units "switch-mode-power-supply" due to detection of FAULT CONDITION having been detected with other circuit or with itself. Read some of my other responses in my fixya profile that deal with BLACK SCREEN repair. If this response useful, rate on fixya. 12fixlouie
Dec 19, 2009 | Samsung Computers & Internet
It's the No Power DELL w2600 TV that , has Powered UP ?
Shame to throw away such a good set.
Sound system integrated inside is worth more then most of the new LCD TVs.
Get parts from guy at
plasmatech@gmail.com
Jun 08, 2009 | Dell W2600 26 in. LCD Television
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
Samsung ST600 Digital Camera Logo
908 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
