My speakers I enter a program to clean my computer, and the speakers went off in the system. And I don't know how to get them back.
  • 185 Answers
May be your volume control properties may affected by that software u enter into volume control pannnel and click the properties and change the settings as u required.
Posted on Aug 16, 2008
Sundenly my speakers don't have a sound technition checked for 2 hours and can't find whats wrong
depending on the operating system open sound in control panel and select the speakers if they are shown and right click and set to default, ensure the check box for "all devices currently playing sound is ticked" if this isnt working try pluging the speaker into an ipod to ensure theve not popped.
Jan 29, 2013 | Dell A215 Computer Speakers
Every time I play music, whether it is streaming from the website or I already have on my hard drive, my computer makes screechy noises and displays a delay in the middle of some songs! Do you know wh
Could be your PC hanging that's why your music has delays and when that happends unusual sounds sometimes occurs like screeching. Have you tried cleaning your unit with CCleaner, google for it its useful on tuning up your unit. That program also has an option to see what programs are starting up during boot. There maybe programs that you don't need to start but starts anyway and that causes lags also.
Oct 01, 2012 | Alienware PC Systems Alienware...
I just bought Bose Companion 2 speakers which I don't know how to connect to my HP Pavillion desktop PC. The pdf instruction booklet does not help. There are multiple jacks (6) at the back of the tower...
You need to connect the speakers to the green jack in your PC.
Check your system sound volume setting to make sure it's not set to MUTE or the volume slider is on or near the lowest position - you don't specify what system you have on the PC so I can't give you an exact pointer but Volume Control generally is found under Programs -> Accessories -> Entertainment.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Bose Companion 2 Series II Multimedia...
I need to close my account from the outside becuase there was something in my account mail that has a virus in is and now my computer is infected and I'm having to get my computer fixed. But once my...
You need to get a really good virus program which will detect the virus on your computer. You also get an malware program too for spyware. Viruses will effect everthying on your computer but before you get your computer fixed try this first.. I used Panda Cloud which is free and it is a really good program! Another good program for malware is IO Security 360. Do a deep scan after you install the virus program and malware program. Another good program for your computer is Advanced System Care 4 with is also free and it keeps your computer working really well and it cleans your computer of files you don't need. It also has tools that lets you know that you have founds and it fixes it.
May 26, 2011 | Computers & Internet
Model ADA885 Power went out. ACP Backup unit worked as usual. When power restored speaker system will not function. Only buzzing sound from speakers. Speaker controls do not work. No response...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 04, 2011 | Altec Lansing Audio Players & Recorders
Only one speaker works
try swapping the speakers around if the problem still persists either the speaker is faulty or
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps don
Mar 11, 2011 | Philips MMS 321 Computer Speakers
My computer crashed recently and it deleted everything off my harddrive. Now my computer is saying no audio device, and I don't know what to do. I tried to unplugg them and see what happens, but nothing. I...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps don
Mar 08, 2011 | Kinyo Audio Zone 2.0 Sound System Computer...
Acer Computer... extremely slow response time.
try installing ccleaner. It is free software from download.com
once installed go to the tools then to startup and disable anything running in the startup. then run cleaner. If it is still running slow change the ram. There may be some kind of driver issue with your speakers. They may also be bad speakers. Who knows' but the netbooks are not going to have the best quality of sound anyways. worst case buy headphones or external speakers
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Tried to remove PC Mighty Max and cannot!
Is it now missing from add/remove programs.Windows add/remove
is a useless program anyway, you can go into safe mode(reboot your pc tap f8) and delete the folder that is in your program files. Return to normal operation. There are two ways to remove the registry keys
for this program,manual and a free cleaner,called Ccleaner, you should get this and clean your registry,besides it is good to clean
it when you install and uninstall programs. Below is the link to the free cleaner,its not bad for free.
http://www.ccleaner.com/download
Apr 01, 2009 | Microsoft Windows XP Home Edition
My three front speakers stoped working
Ob
viously something reset itself. Do a systerm restore back to a date when everything was working--that should fix you up simplest.
Nov 01, 2007 | Logitech Z-5300 Computer Speakers
50 people viewed this question
 Grubhead
Grubhead
