Question about Honda Pressure Washer PSI 3000
How to start GX340 powerwasher after winter. - Honda Pressure Washer PSI 3000
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
My powerwasher Generac model# 0060223 is spraying water I think from the pump. Any ideas as to what is wrong.
if you did not winterize it it might have froze up and busted I was given one years back that si what happened to it before I got it and luckily I was able to fix with some lock tight spread on a thin layer and clamped it tight for several days to cure out
Apr 17, 2015 | Generac 6022/5989 2700 PSI 2.3 GPM 196cc...
Pressure washer rope recoils to quickly when pulling to start
I'm sorry if I'm not quite understanding the question.
Are you saying the rope MAY be too short and so the amount of pull available is also shortened?
Feb 23, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a Honda EP5000 Generator set with GX340 engine, the problem is that too much oil is discharging from OHV cover into the Air Cleaner via that rubber pipe and spilling out from it. Engine also smokes...
Hi,the quick,but not final fix for this issue is to use a oil additive similar the one-s from the cars,but make sure you are using the one required by the fuel type.The engine is worn out,needs overhaul,soon or later.Good luck,regards
Nov 01, 2014 | Honda 6kw 120/240v, Gx340, Recoil Start...
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
Waster comes out of the powerwasher around the plastic frame in the front
ok you have a leaky seal . sound like someone left water in pump over winter and it may have froze , when thathappens ice expands and either cracks frame or pushes out seal.
Mar 17, 2010 | Karcher Garden
Husky 2600 psi Powerwasher will not start, it was only used once, in 2008. gas was left in the powerwasher over last winter. I followed the 13 steps on hooking it correctly and turning it on etc.. when I...
You may have to take out the carb and get it cleaned / air-blown out. Looks like some little valve is stuck. Also make sure you are getting enough sparks at the plug tip. If you have left it long in a damp place it may take several pulls on the cord for the engine to fire-up and run. Try spraying some WD-40 into the cylinder through the plug-hole. Then pull the cord again. After a few pulls remove the plug again, and put like a spoonful of clean 10/30W engine oil into the cylinder, and keep pulling the cord until you see some smokes at the exhaust. If the engine fires up and run a few minutes, but stops later. The engine might be out due to incorrect oil/fuel misture.
Oct 20, 2009 | Garden
Honda Pressure Washer PSI 3000 Logo
50 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
