Question about Scalextric C2788 Peugeot 307 Wrc 25
Peugeot 307s all brake lights and rear lights not working
    Genius:
  • 1,386 Answers
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you remove the positive battery connector and let it sit for atleast 5mins. or more before reconnecting it. This will reset the system and can get your vehicle back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Aug 17, 2011
Hey hope someone can help my Peugeot looxor 50 has no light front and back brake lights do work and so do indicators changed my rear shock one day lights havent work since any suggestions thanks
Make sure that a ground wire is not near the area you worked on or any wiring for that matter that may have been bumped during shock replacement .
Jan 04, 2016 | Peugeot Cars & Trucks
Peugeot Scooter. Vigue 49cc. Why have lights stopped working?
Harness has worn through on frame somewhere or harness plug is loose somewhere. Check back through the power to ignition switch then light switch etc. Work methodically.
Jun 02, 2015 | Peugeot Cars & Trucks
Peugeot 206 2005 xr model stop lights not working
If none of the 3 lights are working and the bulbs all check out then I'd suspect the brake switch.Normally tucked under the dash at the far end of the brake lever.Peugot rear lights are prone to corrosion at the wiring connector behind the light cluster.
Jan 14, 2015 | Vehicle Parts & Accessories
How to remove the lens housing unit on a rear peugeot van ?
Can you get to the bulb from inside the van? You may not need to remove the whole assembly. The lens can't be removed by itself - it's part of a complete assembly - housing and lens in one unit.
Aug 06, 2014 | 2010 Peugeot Partner Grand
Brake light works, rear side light works but when
make sure the bulbs are good try replacing them
if that isnt it sounds like bad ground circuit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | 1994 BMW 3 Series
No fans,no hot air ,no cold air
Read the owner's manual! The fuses are all listed in there..
Its just as possible that its an ecu fault or multiplug connector at fault, or the blower motor. Im afraid 307s of this era are notorious for electrical faults...
Jan 23, 2009 | 2005 Peugeot 405
Peugeot 106 independence brake lights
Ok man, i don't if that helps you, but when i tried it in my 1989 peugeot 205.
Try this: put on the hazzard lights and that will test some of the brake light circuit.
Jun 18, 2008 | 1987 Peugeot Liberte
Scalextric C2788 Peugeot 307 Wrc 25 Logo
363 people viewed this question
Top Scalextric Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Scalextric Toy Expert? Answer questions, earn points and help others
