Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Push on button and nothing no lights how to tell
Push on button and nothing no lights how to tell if lamp is bad
    Genius:
  • 1,030 Answers
Not always but 95 percent of time if you remove the bulb the bulb will be burnt out like a regular light bulb and or shattered. At the shop the first rule was always remove the bulb and look at it. DO NOT touch the front or lense part of the bulb.
Posted on May 27, 2011
My farmall H will not turn over at all. Battery is good. 6volt. Manual push button start. New starter . Nothing Help please.
Haven't work on one these but following is what I use for finding bad grounds even though I got several meters.
You can rig up test light using some wire and a 6 v lamp bulb. It won't give an exact voltage readings but a brightly lit lamp indicates at the present of the voltage.
For testing for bad grounds use the main battery ground connection and probe the ground connections around the starter while trying to start. The test light will make it safer as you are just looking for a lit lamp will trying to start; just place the lamp where you can see it from the starting position. The test light will light if there is a bad connection between the starter's ground and the battery ground.
The same setup can be uses to probe to see if voltage is even reaching the starter through the switch and solenoid connections. If the starter solenoid is separate from the starter it can have a bad ground too and will not operate.
Nov 30, 2014 | Cars & Trucks
How do I shut off the headlights on my 1997 Mercury Mountaineer?
You need a repair shop
The GEM Module as ford calls it or body
module may be bad or the light switch etc
Mar 01, 2013 | Mercury Mountaineer Cars & Trucks
My projector it not working! i press the power button and it green light but it not light show can you please help me and also colour keep flashing.
Sounds like the lamp might have blown. Sometimes the projector can't tell if the lamp is blown, so the usual red indicator light doesn't show.
After the projector is on, if you push menu on the remote do you see anything? Maybe the brightness is just turned down all the way. If you see no menu when you push the menu button it's time to inspect the lamp.
Open up the projector and pull out the lamp. You'll probably need a screwdriver to remove the cover, and then another screwdriver to unscrew the lamp and pull it out. Be careful not to touch the bulb's insides. Is the lamp on the inside of the fixture bulbous, or cracked. Look closely.
Mar 28, 2011 | Optoma EP721 Projector
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60XS955 Powers off and on every minute
The lamp light will not come on especially if it lights up during bootup from a cold start. The lamp only lights up on Sony when the lamp shatters in its housing and the system can't ignite the lamp from a cold startup, Sometimes it does'nt light up then. So if it lights when u first cut it on the sysem thinks its ok... But lets verify if the lamp is the problem.
With the tv off using your original remote, Press Display button-----channel 5 button----and Volume up button then Power button within 5 secs of pushing the first button, Screen should come on with a diagnostic screen, Look at the lamp driver option and see if its recorded any numbers to the right of it, if so then this is telling you that the lamp has stopped or tried to ignite that number of times..
Push the number 8 key then enter to reset the numbers back to zero.Turn off power now turn on the television and wait until it happens again, at this point go back to diagnostic as explained eariler and see what it has recorded. If it has recorded a 1 on the lamp driver then replace your lamp. Reminder: Once you have replaced the lamp go to diagnostic screen again and reset the numbers back to zero.
Hope this helps...Thank you
Delhielectronics@live.com
Sep 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
PT-52lcx65, lamp blew, replaced lamp and ballast...nothing
If you don't get a LED power indicator I would suspect the power supply. Could be as simple as a blown fuse..
Apr 02, 2009 | Panasonic PT-52LCX65 44" HDTV
My TV will not come on.
Have you checked the lamp? You can cosult your owners manual to find the lamp access panel. Once you determine that the lamp is bad, you can find one anywhere on the internet. Let me know if I can be of further assistance
Jan 18, 2009 | Televison & Video
Wont turn on
I have the same problem. When I push the green button nothing comes on - just the green LED keeps blinking.....could you manage to find the solution
Sep 28, 2008 | InFocus User guide, LP500 / 530 Projector...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
