Question about Garden
I checked for spark with the plug unscrewed but plugged in, the rounded the plug thread on the motor and pulled the string, repeatedly. I got one spark early on but not another. Do I need to replace the magneto?
    President:
  • 1,545 Answers
Not necessarily. Before you consider replacing the ignition module, I would check the "air-gap" that is between the ignition's module legs and the magnets in the flywheel. If it is too wide, a weak spark or no spark at all could be observed. It should be in the neighborhood of .010" or so. This is just about the thickness of a standard sized business card and in fact, the card is readily used as a feeler gauge for this purpose due to the trouble using a metal feeler gauge on the magnets. Post back if you need instructions to check and/or set the "air-gap."
Posted on May 27, 2011
How do I change spark plugs toyota corolla 2002
First you will need the correct size spark plug socket and a longer extension bar for it. Most sets are not expensive to buy.
ONLY REMOVE ONE PLUG LEAD AT A TIME!!!
Make sure there is no loose dirt on the area your working.
Using it's cap, (not the wire), pull out the first plug lead. Insert the socket and gently push into place. Plug sockets have a rubber insert fitted to grip the plug as you lift it out. Using firm (but not rough) pressure, unscrew the old plug.
For the new plug, REMOVE the ratchet and insert the plug into the socket using the rubber insert to hold it in place. Lower the plug into place and GENTLY screw it into place, using the extension bar like a screwdriver. If you hit resistance unscrew and try again. A stripped screw thread is VERY expensive to fix. Tighten the plug to 35Nm (25ft/lb). REFIT the plug lead BEFORE moving to the next spark plug.
Repeat for each spark plug in sequence.
Jan 10, 2018 | Toyota Cars & Trucks
How to change spark plugs
You will need a 12 mm wrench and socket, a 10 mm socket , an extension and the socket for your spark plugs, and an intake plenum gasket. Start by pulling the positive cable from your battery. Next pull the intake cover off the top of the motor. On the drivers side you will see 3 coil packs or "cops" ( coil on plugs) those have two 10mm bolts, one on each side. Remove those , pull the coil, unscrew your spark plug with your socket, and replace.
On huge passenger side you will have to remove the upper intake arch (plenum) to get to the remaining three plugs. Repeat process from the drivers side. !!!!replace your intake gasket when you remove the upper plenum or you will have a vacuum leak.
Apr 16, 2014 | 2007 Nissan Frontier SE Crew Cab
The trimmer was running fine when I ran out of string. I add new string and now I can NOT get the trimmer to start! I tried unscrewing the spark plug, making contact to the metal of the engine and...
Adding a new string has nothing to do with your spark. If your checking for spark make sure the spark plug is grounded to the engine either use a screwdriver to help you ground it. Lay the plug on the screwdriver shank then pull the cord. If still no spark remove a wire of the ground switch then try again. If you get spark then the switch is the issue if still no spark then you may have to check the leg gap of the coil to the flywheel. Adjust to around 11 thou if you can. If still no spark then i'd go on record to say you have a faulty coil.
Oct 20, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Spark plug blew out
Did it come unscrewed or did the threads pull out of the head? If the threads pulled out then there are repair kits that will allow you to repair the hole without pulling the head. If you are not comfortable trying this then many repair shops or machine shops will do it. If the plug came unscrewed then rent a thread chaser, clean the threads and put a new plug back in.
Feb 16, 2013 | Chrysler Cars & Trucks
Need to kb\now how to change spark plugs on my 2001 sonata
Follow these steps on how to replace thespark plugs. 1. First, you turn off the Sonataengine and allow it to cool. This normally takes about 30 minutes. 2. Raise the hood and locate thespark plug cables along the side of the engine. Spark plug cables are normally1/4 to 1/2 inch thick and plug directly into the engine. 3. Grasp the cable by its boot.This is the thicker piece that covers the spark plug or spark plug well. Turnthe cable back and forth until the lock releases. Pull back on the cable toremove it. Complete the replacement process for each plug before moving on tothe next. Slide the socket, extension and wrench over the spark plug. Turn thewrench to the left to unscrew and remove the plug from the engine. Spark plugsockets have a cushion inside that grab the end of the plug to hold it inplace. 4. Clean the well and boot withthe wire brush. Do not rub hard on the well or boot or it will cause damage.Spray silicon in the boot and on the spark plug threads, so you can easilyremove the spark plug the next time. 5. Insert the socket into the welland gently thread it into the engine. Test the tension with the tester. Thetension a spark plug needs varies by plug manufacturer. Check the package tofind the correct tension. If you need more tension, tighten the spark plug. Forless, loosen or unscrew the plug. 6. Place the cable back onto thespark plug. Repeat Steps 2 through 7 for the other plugs. Work your way downone side of the engine and then down the other as you replace or clean thespark plugs. This are the things you need for the job, 16mm spark plug socket,Socket wrench with extension, Wire brush, Silicon spray, New spark plug,Tension tester
Jan 10, 2011 | 2001 Hyundai Sonata
HOW TO REPLACE SPARK PLUGS
    Follow this steps on how to replace the spark plugs,
    1. Locate your spark plugs before beginning. Accessing the spark plugs can vary greatly depending on the model of motorcycle. The Ninja series bikes place the spark plugs near the top of the motor, hidden beneath the fuel tank and air box.
    2. Remove the seat and fuel tank. Locate the bolts that secure the fuel tank to the frame and remove them with a socket wrench. Lift the fuel tank upwards and disconnect the fuel lines. Pull the entire tank away from the motorcycle and set it aside.
  • 3. Unscrew the air box lid with a screwdriver and remove. Remove the air filter and locate the bolts that secure the air box to the motor. Unscrew the bolts with a screwdriver and pull the air box off of the motor. Take note of the locations of any wiring or hoses that may be attached to the air box before disconnecting them.
    4. Pull the spark plug wire off of the first spark plug and clear the plug cavity with compressed air to remove dirt or debris that may been trapped. Remove the spark plug with a spark-plug socket. If needed, use a socket extension to reach the spark plug in the cavity.
    5. Insert a new spark plug into the cavity and carefully tighten with a spark plug socket. Slide the spark plug wire onto the end of the spark plug and press down until the wire clicks into place.
    6. Repeat as necessary for any remaining spark plugs. Reinstall the air box and reconnect any hoses or wiring removed earlier. Insert the air filter into the air box and seal the lid by tightening its bolts with a screwdriver
    7. Reinstall the fuel tank, reconnecting the fuel lines and tightening the mounting bolts with a socket wrench. Replace the seat.
    Thank you
Nov 23, 2010 | kawasaki ZX-12R Motorcycles
I pulled the power stater pull string but my powerwasher won't turn on, there's gas, the water hose is on, could it be the spark plug?
you can check for spark by unscrewing the spark plug , place the rubber boot back on the plug and have someone gently pull the starter rope while you hold the electrode of the plug so that it touches the engine block. make sure not to touch any part of the plug or you will get a shock! only hold the plug by the rubber boot! while a helper pulls the rope you should see a spark in the electrode of the plug if you have it grounded against the engine case. if you have spark then try spraying a little starter fluid in the spark plug hole or the air cleaner. either will work and should get it to fire if it has spark. if it starts and then shuts off, your carb is probably gunked up.
Apr 28, 2010 | Mi T M WP-3000-4MHB Pressure Washer
Spark plug thread broke off while trying to get it out!
Their are three options;  A tap of the proper size may clean up the existing threads. The second , is a kit called a Heli-Coil where you remove all the threads , tap it out bigger and instal a Heli-coil to bring the threads back to the original size.  The third is to tap it to the biggers size and then look for an oversized plug. I was able to do this for a lawnmower many years ago and do not know if oversized plugs are still available.
Feb 15, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
1999 Dodge grand Caravan Tune up
i hope this helps more. its hard to explain these things with out being at the car. but i hope this helps. it pretty easy just pull one wire off, unscrew plug from moter, replace with new one, replace with new wire. and repeat 4 or 6 times depending on what engine you have. but write back with anymore specific questions you have.
When you're removing spark plugs, work on one at a time. Don't start by removing the plug wires all at once, because, unless you number them, they may become mixed up. Take a minute before you begin and number the wires with tape.
  1. Disconnect the negative battery cable, and if the vehicle has been run recently, allow the engine to thoroughly cool.
When removing the spark plugs on the V-6 engine only on the firewall side, it may be necessary to remove the windshield wiper/motor module assembly from the vehicle. This will allow more room to work between the engine and the engine compartment firewall. Refer to for removal procedures.
0900c1528003c1aa.jpgFig. 3: Hold the spark plug boot firmly, while giving it a slight 1/2 twist in each direction before pulling it off of the spark plug. remenber do this one at a time. replace the whole wire with new one.
  1. On V-6 models only, remove the windshield wiper/motor module assembly from the vehicle for access to the spark plugs on the firewall side.
  2. Carefully twist the spark plug wire boot to loosen it, then pull upward and remove the boot from the plug. Be sure to pull on the boot and not on the wire, otherwise the connector located inside the boot may become separated.
  3. Using compressed air, blow any water or debris from the spark plug well to assure that no harmful contaminants are allowed to enter the combustion chamber when the spark plug is removed. If compressed air is not available, use a rag or a brush to clean the area.
0900c1528003c1ab.jpgFig. 4: Once all dirt is removed from around the spark plug, carefully loosen and remove the plug 0900c1528003c1ac.jpgFig. 5: Pull the used spark plug out of the cylinder head once it is completely loosened Remove the spark plugs when the engine is cold, if possible, to prevent damage to the threads. If removal of the plugs is difficult, apply a few drops of penetrating oil(WD40) or silicone spray to the area around the base of the plug, and allow it a few minutes to work.
  1. Using a spark plug socket that is equipped with a rubber insert to properly hold the plug, turn the spark plug counterclockwise to loosen and remove the spark plug from the bore.
WARNING Be sure not to use a flexible extension on the socket. Use of a flexible extension may allow a shear force to be applied to the plug. A shear force could break the plug off in the cylinder head, leading to costly and frustrating repairs.To install:
  1. Inspect the spark plug boot for tears or damage. If a damaged boot is found, the spark plug wire must be replaced.
  2. Using a wire feeler gauge, check and adjust the spark plug gap. When using a gauge, the proper size should pass between the electrodes with a slight drag. The next larger size should not be able to pass while the next smaller size should pass freely.
  3. Carefully thread the plug into the bore by hand. If resistance is felt before the plug is almost completely threaded, back the plug out and begin threading again. In small, hard to reach areas, an old spark plug wire and boot could be used as a threading tool. The boot will hold the plug while you twist the end of the wire and the wire is supple enough to twist before it would allow the plug to crossthread.
WARNING Do not use the spark plug socket to thread the plugs. Always carefully thread the plug by hand or using an old plug wire to prevent the possibility of crossthreading and damaging the cylinder head bore.
  1. Carefully tighten the spark plug. If the plug you are installing is equipped with a crush washer, seat the plug, then tighten about 1/4 turn to crush the washer. If you are installing a tapered seat plug, tighten the plug to specifications provided by the vehicle or plug manufacturer.
  2. Apply a small amount of silicone dielectric compound to the end of the spark plug lead or inside the spark plug boot to prevent sticking, then install the boot to the spark plug and push until it clicks into place. The click may be felt or heard, then gently pull back on the boot to assure proper contact.
Jan 03, 2009 | 1999 Dodge Grand Caravan
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
