Question about Garden
Honda harmony 1011 - hydrostatic - when blade belt is engaged, the belt pulls off the PTO pulley and does not engage blades. How do I adjust the PTO pulley?
  • Paul Schultz May 30, 2011
    I have already tried the PTO adjustment but my issue is with the PTO pulley that engages the belt. It does not appear to be level and as a result the belt pulls out from under the L bracket that is supposed to hold the belt in the pulley groove each time the PTO lever is engaged.
  • 10,319 Answers
Is the belt very old? if so it is stretched and needs to be replaced. All belts with a heavy fabric woven around the belt averages a 5 year life span
If it is a simple rubber/nylon corded belt one year is its life span
Posted on Jun 05, 2011
  • 19,396 Answers
Hi.
Idler pulley and PTO pulley heights cannot be adjusted. The two pulleys look slightly off level, that is normal. If the belts have rolled out, then they must be replaced. If a belt rolls out even once, then replacement is needed. That is likely the problem.
Replace the belt with an original one. OEM replacements may give more problems. Use the contact on the user manual to get parts.
To replace belt and put the belt in tension, see instructions from page 83 of this user manual.
Regards.
Ginko
Posted on May 30, 2011
    Guru:
  • 666 Answers
I haven't used one of these so it's hard for me to say how to it the easiest way. Anyhow, I got a manual for it and looked for the PTO adjustment. Check the image below. Here is the Service Manual as well go to page 70 and there you will find PTO adjustment.
Thank you for choosing FixYa! should you have follow up questions please feel free to post it here and i'll get back to you ASAP. Enjoy the weekend!
Posted on May 27, 2011
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
When running the mower, it shuts off immediately when trying to engage blades(pto)
Hi Digger:
I've two possibles come to mind for you to check.
1) Engine OFF - Make sure that all of the blades and pulleys can turn freely.
2) Engine OFF - Double check belt routing. Move engage lever ON/Off and look at what movement happens. It may be that the belt is on the wrong side af a mounting flange and binds when engaged.
Cheerfuls.
Sep 18, 2015 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
I engage the mower blades, put the tractor in drive and the blades stop
sounds like the safety switch is out of adjustment
Apr 06, 2012 | Garden
I have a Kubota TG1860 G riding mower. the blades have stopped engaging. I have replaced the push/pull switch, didn't work. It clicks like it wants to work but doesn't engage. What else can I do?
belts,solenoid,ignition switch and the PTO, you can hook 12v directly to PTO and see if it is engaging, the ignition switch feeds 12v to the PTO, the switch/solenoid engages with the help of the pulleys and belts, just a matter of figuring if its the belts(or in may cases the tesioner pulley) Hope this helped Tim
Apr 18, 2011 | Garden
Replaced belt for mower thought i put it all back correctly blades engage when key is turned engage lever to off what did i do wrong
If you look at the motor pulley area, there should be two different pulleys with a PTO clutch between them. The PTO clutch has wires going to it, because it is operated electrically by the blade engage switch.
It sounds like you could have accidentally put the mower deck belt onto the main drive pulley (which turns all the time) rather than the pulley that is farther out from the engine, which only turns when the engage the blade switch. If so, just loosen the mower belt and move it to the right pulley.
Jun 09, 2010 | Garden
DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Apr 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a model 13aq609g063 troy bilt riding mower. It has a 18hp briggs & stratton, 2 cylinder, ic engine. the engine runs fine, the bottom pulley on the engine for the pto belt turns when running, and...
Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
Nov 07, 2009 | Garden
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
1,070 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
