Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
I want buying the extension of lace hard drive 160 g between the adapter and the hard drive.
  • LaCie Master
  • 27,725 Answers
This will depend on HARD DRIVE whether ide the ide will have 40 pins or sata the sata will have 8 copper slat type also PSU power supply unit ide or sata power connecters these days they usually supply both next MOTHERBOARD if has ide and sata plugs the ide will be a flat ribbon type with 40 pin plug ends the sata will be 8 copper slat type usually a bit thicker
hope this helps
Posted on May 27, 2011
  • Brian Sullivan
    Brian Sullivan May 27, 2011
    you could get this on Ebay if you dont have an account you will need to create one
    Add Email adress
    Add Bank Acc
    Add Credit Card
    also add your postal adress
    also add a paypal account
    when you get to the paypal login page at the bottom you will see new to paypal sign up tab
    paypal to create an account
    paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
    be very specific when you type in the search
    always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
    you will even see the pictures of your item so you cant make a mistake and get them home delivered
    hope this helps
Toshiba satellite c655d power problems
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 30, 2012 | Toshiba Satellite P200-13Z Laptop AC Power...
PC Does not Starts
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 13, 2012 | Dell XPS M1530, M 1530, PP28L Series...
Not detected show
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps you
Mar 19, 2012 | Computers & Internet
REPAIR A HARD DRIVE
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
Mar 09, 2012 | Western Digital Passport Computers &...
Boot disk not recognisable
hope this helps you
Mar 04, 2012 | HEWLETT-PACKARD Hewlett Packard 465899-003...
Hard drive disk will not spin
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
check you CPU make sure its securely seated and has thermal grease might be getting to hot
hope this helps you
Jan 08, 2012 | Western Digital Caviar WD400BB 40 GB Hard...
The pc don't reconise the hdd
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
hope this helps you
Jan 05, 2012 | Transcend 64GB IDE 2.5inch Solid State...
Western digital lap top drive does not seem to spin at start up 160 gb
hope this helps you
Nov 28, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Can I add memory to a 9300 dell inspiron? Presently I only have 50g. Is it difficult to perform?
yes u can extend it by external Hard disk.
I think not possible to configure ur hardware configuration
Jun 16, 2009 | Dell Inspiron 9300 PC Notebook
Simpledrive external HD,repeatedly is recognized,then dissconects
Try connecting it to a different computer, it the problems occurs on a different computer then it is most likely the Simpledrive.
The next thing I would try is to test the power adapter (if it has one and not it is internal) with a multimeter, check the output voltage (the voltage is printed on the label on the adapter) it should be slightly higher than the label's voltage.
Try another compatible adapter and see if this solves your problem.
If it is not hte adapter then it is the USB electronics in the unit is faulty, the hard drive in the unit would be OK.
You could buy a new USB hard drive case adapter and transfer your hard drive to this case and you will have an exernal hard drive again.
OR
Borrow an USB hard drive adapter first to test your hard drive before you buy a new USB hard drive case.
Jan 26, 2009 | SimpleTech SimpleDrive...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
62 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
