Question about Garmin GXM 51 Weather And Audio XM Satellite Receiver Antenna
I have a garmin 4212, a 4210, and the Garmin gxm 51 xm receiver with a subscription. How do I get audio XM. I can tune the xm receiver but don't know how to hook speakers to the garmin network. I have been through the manuals but can't find how to connect speakers or an audio system to the garmin network.
SOURCE: GPS & XM
I have both a 660 and xm...no problems
Posted on May 04, 2008
marcelbakker
  • 174 Answers
SOURCE: Extension cabling for Garmin GPS
Hmmm, it uses mini usb cable, 1.8 mtrs, thats about 6 foot...
check here http://www.pc-mobile.net/pspgps.htm
Posted on Jun 10, 2008
SOURCE: How do I disasble Bluetooth feature on GARMIN760
On the nuvi 760 to disable the bluetooth do the following.
Go to tools and then settings, select Bluetooth. In the Blutooth screen select Bluetooth again and select disable.
Posted on Dec 29, 2008
  • 20 Answers
SOURCE: Garmin 2730, Xm radio is on show's stations, I see
Did you try cleaning the output jack with a q-tip and alcohol? Otherwise you might have to send the unit to garmin if it is worth it to you.
Posted on Aug 19, 2009
  • 20 Answers
SOURCE: loose XM antenna connection for garmin 2730
Try cleaning the end of the antenna with alcohol and a qtip. Also the unit itself. Are you able to hook up usb no problem? If so it is the antenna. It is either dirty or broken.
Battery went dead on Garmin 396. The unit worked with airplane power in GPS mode but displays "waiting for data" on Nexrad Radar. I have downloaded version 5.30 I should alao mention that...
You indicated that the battery went dead. Does the new battery work correctly? That is, does it show a full charge when you've had it plugged in overnight and disconnect the power? Try plugging it into AC power overnight and verify that the battery is accepting and holding a full charge. If it isn't, then unplug and turn the unit on and allow the battery to run all the way down. Then charge it fully. This resets the charge indicator. You may have to repeat it once. I did this and was able to again show that both my new and my old battery were working o.k. They should show about 8.1 V fully charged.
About the Nexrad problem. In the past I would need to refresh the XM receiver when this happened. XM walked me through it and I have the steps, but the links are no longer working. Maybe it is no longer required since the XM link now jumps to SiriusXM. I've not needed to refresh for a couple of years and I suspect they eliminated that requirement.
To verify that the XM antenna is connected: Turn unit off. Connect the XM receiver. Simultaneously press "on" and "enter" keys- hold both until data screen appears, which takes about 5 seconds. Second line from bottom indicates if it is seeing the XM receiver. This helps isolate where the problem is- i.e. if you have a faulty receiver, bad connection or a software problem. The only contact I know of now is Garmin 800-800-1020. They can give you the XM contact if the problem is on that side of the unit. There is other data here which may be of interest to you on this page. Turn unit off to close this window.
If you need your XM radio ID, turn 396 on. Press menu, menu, scroll to XM, then right to Info. XM Receiver ID is there. Write it down in case you talk to XM or they give you a way to refresh. There are other menus you can get into but if they show a problem I don't know the solution other than contacting Garmin and I don't have my XM receiver home so can't verify the steps.
Mar 28, 2011 | Garmin Replacement GARMIN GPSMAP 396 GPS...
Dnx-7100 and XM
just check whether the connections are proper
Jun 21, 2008 | Kenwood DNX7100 Car Video Player
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
Garmin GXM30 stopped working. what is the usual reason for this? Driving along in the morning, the sound started to sound'' fuzzy'', I went to try a different channel and immediatly lost all XM radio in...
There is very little to those pucks. If you have tried it in two devices then the electronics have gone bad. Blame a solar flare or something but it will need to be replaced
Apr 15, 2017 | Garmin GXM 30 Antenna
KVT-719 NAV button not highlighted unable to select
Well I see no help here, but emailed kenwwod and they told me:
The Garmin menu is not accessible from the main source select screen, only thru the V.Select which you have already discovered.
The reason why "NAV" is displayed as an audio source is if you were to add a GMX30 XM Radio/NavTraffic antenna, you would be able to access XM radio (subscription required). So unless you have the GXM30, you will never use that source key.
Jul 12, 2008 | Kenwood KNA-G510 GPS Receiver
Installing XM on my Motorcycle
Pick yourself up a Garmin Zumo 550, it has a navigator, MP3 player, photo viewer, and XM (Radio, Traffic, & Weather) and best of all the music gets interupted when it's time to give you directions.
May 03, 2008 | XM Radio (XMP6000)
GPS & XM
May 01, 2008 | Garmin Nuvi 660 GPS Receiver
Dnx-7100 and XM
the Garmin GXM-30 antena works
Apr 04, 2008 | Kenwood DNX7100 Car Video Player
No traffic and weather showing-using GXM 30 smart antenna with subscription
the only idea i have is contacting xm asking if they can resend the traffic signal to your unit.
Jan 29, 2008 | Kenwood DNX7100 Car Video Player
XM radio sounds like crap!!!
if the xm and gps antennas are close together this will happen. u will have to move one to the front and the other to the back of the vehicle.
Nov 03, 2007 | Kenwood DNX7100 Car Video Player
Garmin GXM 51 Weather And Audio XM Satellite Receiver Antenna Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
