Question about Sanyo 18KS52 Air Conditioner
Sanyo KS3632 Air Conditioner. Unit will not turn on at all, I checked remote with a cell phone camera, it's working fine. Unit worked perfectly last season. Checked the breaker, it's fine. Toggled the power switch, still nothing. Any suggestions?
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: I am looking for a copy of the USER manual for a
here u go http://www.oceanairdist.co.uk/assets/pdf/service/Sanyo/Service%20Manual%20SAP-KMRV93.pdf
Posted on Jun 14, 2009
  • 674 Answers
SOURCE: ice on valve of Sanyo c1251 outdoor unit
Make sure you air filters are clean then make sure your fans (indoor and outdoor) are running. If these are OK then you need to get your refrigerant charge checked.
Posted on Jul 04, 2010
  • 13 Answers
SOURCE: ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Posted on Jul 20, 2010
  • 149 Answers
SOURCE: where can I find a
the filter usually is where the hot air is brought into the unit should not be hard to find
Posted on Aug 21, 2010
Cant get the controller for my fujitsu auy18asd to work with the unit theres no beeping or nothing
An easy way to check the remote is to use a digital camera. Turn the camera on and point the remote at the lens. Look at the camera screen and press a button on the remote. If it is working, you should see the transmitter flash a purple/blue colour. This is not visible with the naked eye so you have to use a digital camera to see it. A phone camera works fine. If you see the transmitter flashing, the remote is probably ok and the receiver board or controller board in the head unit is faulty.
Jun 29, 2014 | Fujitsu 18C1 Air Conditioner
My AC unit just died out of the blue.
Sounds more like a bad breaker possiably not getting power to your unit I would check the breaker first
Jul 21, 2013 | GE "General Electric AEN10AQ 10,000 BTU...
Samsung Air Conditioner AS12AA9B)MC
interference of the cell and put it in the camera after the interference control and hit the button while you will see from your cell phone if a light turns on whenever you press the buttons on the control then it is ok and the problem is the indoor unit.
Apr 12, 2012 | Heating & Cooling
Have a LG Split -can't get it to heat. Air conditioner works fine, when I set the remote to heat all that happens is the blower works.
If it does not start heating after a couple of mins check change over valve and coil located in condensing unit if it's stuck on cooling sometimes you can tap it to free it but if it is sticking it will need replaced
Nov 23, 2011 | LG Heating & Cooling
Air conditioner unit on the wall not working, and the remnote does not turn it on, the indicator lights are not lit either.
Please check teh power to the wall unit first, then if this is present check the remote control, check the battery. Point the remote to your phone camera and see if the camera detects the IR emission. If so the remote is working and the power supply has failed on the AC unit.
Open to check on the main power circuit , the program controller circuit.
Jun 17, 2011 | Heating & Cooling
Jul 20, 2010 | Sanyo Split System Air Conditioner
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
How do i set unit for moisture removal
there would be a button nameng mode on your remote control press it untill it shows dry mode now it will remove moiture from the room as long as it works in dry mode.
Jul 09, 2009 | Sanyo 12KHS71 Split System Air Conditioner
May 08, 2009 | Sanyo 18KS52 Air Conditioner
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
Sanyo 18KS52 Air Conditioner Logo
192 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
