Question about Rinnai Heating & Cooling
I have a Rinnai Granada MK II that the flame just swtches off sometimes and other times its works fine do you why?
3 Suggested Answers
  • 4736 Answers
SOURCE: I have a Granada Mk II in very good order. No
I seriously doubt, that the heavy rains you have been experiencing has anything to do with what you have described. It sounds more like, there may be a fluctuation in gas pressure to the unit or the Pilot Assembly (Particularly the ODS (Oxygen Depletion Sensor) may need cleaning.
The gas pressure fluctuation would have to be professionally checked. However, if you're handy and you don't mind taking the front of the heater cabinet Off, you can clean the Pilot Assembly yourself.
I have included a link that you can reference or download and print on how to clean the pilot assembly. As they say, "A picture is worth a thousand words." Just find the Pilot Assembly that matches yours. http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I have also included a link to the Owners Manual for your heater, in case you have misplaced yours.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/operations/120.pdf
I hope all of this information has helped you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 14, 2011
SOURCE: My Rinnai Granada Mk11
our rinnai grenada mk11 will not contiue to run after release of button. pilot light is still on
Posted on Jun 25, 2011
Rinnai Granada Mk2 has a noisy fan
Clean it and lubricate the bearings.
Jul 30, 2014 | Rinnai Heating & Cooling
Rinnai granada MKII
The conversion requires new jets in the unit and readjustment of the air /gas ratio shields. Use a qualified gas specialist for the conversion .
Jun 11, 2013 | Heating & Cooling
My Rinnai Granada Mk11 Portable Gas Heater starts well but the flame goes out when I press Medium Heat.
There are a several of things that can cause this problem:
1. The Oxygen Depletion Sensor (ODS) is clogged and reads the Oxygen Level in the room as
Unsafe for Operation. Solution: Clean the ODS, which is part of the Pilot Assembly With canned
compressed & a straw nozzle (like you clean your computer with). It will require some dis-
mantling of your heater,
2. Once Pilot is lit, not waiting long enough for the Thermopileto heatup, before pushing the Medium
button. Allow pilot to burn at least one minute, before switching to any heat selection.
3. Gas pressure problem. Have the gas pressure to the unit checked, as well as the gas pressure
at the gas control valve, while unit is in operation.
If you continue to have this problem after completing the Solution in # 1. Call the Rinnai Helpline
1 300 366 388 or contact your local Rinnai Dealer, who you purchased the unit from.
If you have misplaced your Owner's Manual, here's a link to it, that you can download and print for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Granada252/portable_radiant_convectors.pdf
I hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 17, 2011 | Heating & Cooling
I have a Granada Mk II in very good order. No problem starting the unit. Unit is kept clean and clear of any dust build-up and has been working beautifully.\r\nJust recently, at times, some time after...
Jun 14, 2011 | Bionaire Heating & Cooling
Rinnai gas log heater (royale) keeps cutting out. now it wont stay on at all. the ignition is fine, the gas flow seems fine and the fan works fine. we vacuum the dust out regularly
When you say "it won't stay on at all." Do you mean the burner and the pilot flame shut off together or does the pilot remain lit? Is the unit showing any Fault Codes on the LCD display?
Apr 03, 2011 | Rinnai Heating & Cooling
I have a mk 2 granada 2.8i.the engine cuts out every time i select drive and the tickover is eratic.
Sounds to me as if it's an elctrical fault: check the distributor cap for any cracks or tracks also check the centre contact to the rotor arm that the spring is in good condition. i hope this works as there are many silly small things that can cause these symtoms.. kind regards Ronnie
Oct 06, 2010 | Ford Granada Cars & Trucks
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
How to do ignition timing ford 2.8 mk2 granada
remove and plug vacume line on the distributer and find timing specs on the motor in the vehicle using timing light hook transducer cable to no# 1 cylinder set the idle to manufacturers specs make shure motor is warmed up to operating temp now point thr timing light at the timing plate on crankshaft pulley start the engine and watch for the mark on the harmonic pulley see where it is at when running now if the mark is not lining up with sugested degrees from manufacturer then u must loosen bolt on distributer only loosen 1/4 turn now rotate distributer clockwise or counterclockwise this will make the mark on the harmonic ballancer allign with manufactures required timing specs after aligning marks tighten distributer and unplug distributer vacume line and plug it back into distributer. and test if u need anymore specifics plz read manual carefully good luck
Jun 30, 2008 | 1978 Ford Granada
Heating & Cooling Logo
995 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
