Question about Ryobi Garden
I have a Gas Powered Ryobi CS30 Edge Trimmer. I'm using ACE brand Trimmer Line, .08 in. diameter. I can't seem to keep the line itself from wrapping around the spool. I just don't get it. Do I need to warm the line in the microwave or something, to get it to stay straight. How do I fix this problem?
    President:
  • Ryobi Master
  • 1,545 Answers
I see you having problem with some cheaper brand of "kinky" line. I have had some success by doing the following to the line. Soak the whole package of line in a bucket of water for 24 hours. I am not real sure what this does, but it seems to take some of the stiffness and rigidity out of the line. A problem I get is the line drawing back into the head after extending it through the eyelets. Softer line results in less coiling and I hope it helps you too.
Posted on May 28, 2011
I Have a straight shaft Ryobi SS26 trimmer. I can not get through my edging without the line flying out or breaking at least twice and I don't have a very big yard. What can I do to not have to keep...
use a square line or a star line. make sure you have the right gauge line . go to ace hardware and ask them what is the best preforming line for your trimmer..
Jun 06, 2011 | Ryobi Garden
I have a ryobi #790r the gas lines were bad , in replacing them I find an extra hole in the gas tank I can't figure out what came out of it, I found nothing that would indicate something was missing ...
The best way to state my solution is to give you the instructions I made for just replacing the bad fuel lines on a 2-stroke trimmer. Your Ryobi should fit this bill.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 14, 2011 | Garden
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
What size line does a ryobi CS30m gas trimmer use
The Ryobu CS30 model calls for only .080" line. Other models use larger line and electric models use smaller line.
Oct 03, 2010 | Ryobi Garden
I have a Ryobi 700r trimmer - I needs a diagram of all the fuel line hookups
<div id="ms__id6" class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.<br />If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.</span> </div><!-- from fixya rte -->
Aug 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
Ryobi CS30 straight shaft. I can not get the string head off to replace the line.
There should be a half sphere shaped object over the spool of string. Twist off in a counter clockwise motion and the spool will come off so that you can replace the line.
Jim
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
61 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
