Question about Samsung CLP-350N Laser Printer
Light went out on Magenta, Replace with new cartridge light still off will not print with new cartridge.
    Guru:
  • 352 Answers
Hello.
With a torch look inside the printer for the metal contacts that touch the "chip" on the cartridge, it is possible that in removing the cartridge the pins may have bent and are not reading the cartridge correctly. Remove all the cartridges and use the pins on the working ones as a reference to see if the magenta matches.
I hope this helps Regards GM
Posted on May 27, 2011
My Espon R230 printer has problem with Light Magenta colour, i bought new cartridge but then also light magenta nozzle check is not clear, i think it is printer problem, please help me how to solve it
First you could do a printer test. The printer will print a small pattern with all colours making it possible to check if and if so, what nozzle are blocked. Sometimes the cleaning cycle will help, but sometimes there is just some dirt under the head. Please don't try to remove it with tools if there is something. Just use a thick piece or printing paper to solve that problem. Please check the manual for details. Perhaps the epson site can help you with that:
http://www.epson.com.sg/sites/epson_singapore/support/support.page
Jan 12, 2015 | Epson STYLUS R230 InkJet Photo Printer
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
My Epson R230 printer does print Light magenta and yellow ink
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Nov 18, 2010 | Epson Stylus Photo R300 InkJet Printer
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Ink cartridge installed but cartridge light continues to blink
Have you only replaced the magenta cartridge, or have you also tried the print head. A bad print head can cause the ink to read as empty or clogged.
Mar 15, 2010 | HP OfficeJet Pro k550 Printer
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Magenta doesnt print in proper place
Sounds like the new cartridge has been sitting around for too long. The solid lines are usually due to the drum being exposed to light for too long. The other reason could be the charger roller has been in contact with drum (in the cartridge) for a very long time and probably heat has a part in it as well. Try another cartridge.
Jan 09, 2009 | HP LaserJet 3600n Printer
Canon Pixma IP4300 - cartridge recognition preventing any printing happening.
I seem to be having a similar problem with my cannon pixma 4300 as certain others, i have just recently replaced all the inks with " original" cannon inks and all of a sudden it refuses to print anything, it says that one of the inks is not working, ( Yellow) I remove it, replace it again and the light comes on but when the slide retracts the light seems to go off. any ideas would be great, this seems to be a fault i have read a few times.
Aug 11, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
HP Color LaserJet 2600n
First of all clean the contacts in the printer for the magenta cartridge, if there is no improvement replace the magenta cartridge, if that doesn't work come back to me
Jun 12, 2008 | HP Color LaserJet 2600n Printer
Samsung CLP-350N Laser Printer Logo
74 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
