Question about Bose Wave radio remote control - Graphite Gray Shelf System
2 remotes, neither working, need battery replacement?
  • 345 Answers
More than likely, yes. Remotes rarely fail. However, if they are new, did you remove the little plastic battery tab?
Posted on May 28, 2011
Why isn't remote working after battery replacement?
As long as the battery produces what the remote needs it should work. However the remote itself could be faulty. Or the remote sensor on your device could be faulty. Check that the old battery has not leaked and messed up the contacts. Plus the new battery is actually touching the contacts!
Feb 25, 2016 | Audio Players & Recorders
Mopar remote start stopped working
The remote start may now need to be reprogrammed because it needed a slight amount of power from the battery to remember the settings. Replacing the battery interrupted this. Check the manual that came with it.for instructions.
Feb 28, 2014 | Cars & Trucks
My remote wont work on my grundig gu15wdt/gu15wdpcx, have tried changing the batteries and it still doesnt work, where can i get a new one?
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Lastly, please don't by a remote with confirming it is a remote problem. You have to be sure before thinking of a battery replacement.
Regards.
Jun 09, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
Replacement remote not working after 2 years replaced batteries still not working tv works fine manually do i need a code to reprogram the remote?
it is possible, also check batteries and infrared on television and remote, they may need to be wiped clean. try checking manualsonline.com for appropriate manual for remote codes...without model of remote, i could not check for codes for you.. sorry.
Oct 17, 2010 | Protron PLTV-32 Television
Remote for Sony vcr works intermittently.
Sounds like the connections inside the remote are damaged and might need soldering. Check the connections around where the battery terminals are carefully. Has a battery leaked in the remote?
Jan 28, 2010 | Sony SLV-N500 VHS VCR
Liftmaster 973LM. Remote opener does not work. Replaced battery - still does not work. Original owner left no manuals. Works with outside pad and inside button.
ONCE YOU REPLACE THE BATTERY YOU NEED TO REPROGAM THE REMOTE.
WATCH THE LED NEXT TO THE PROGRAM BUTTON WHILE YOU PRESS THE BUTTON ON THE REMOTE IF IT FLASHES THE REMOTE IS SENDING A SIGNAL AND SHOULD WORK.
IF IT DOESN'T FLASH THE REMOTE BATTERY MAY BE IN BACKWARDS OR THE REMOTE MAY BE BAD - IT IS NOT SENDING ANY SIGNAL AT ALL.
HOPE THIS HELPS
Jan 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Ford F150 remote key does not work after car battery
cbridges2232,
Any luck with your keyless remote issue? I'm having the exact same problem with my Ford F150 CrewCab after car battery replacement.
Oct 07, 2009 | 2001 Ford F150 Styleside SuperCrew
Apple remote control
At the bottom of the remote is a small button that can be pressed by a pin or pen. Press it and the battery will pop out. Replace the battery and you will have a working remote
Mar 09, 2008 | Apple MA128GA Remote Control
226 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
