Question about Canon Pixma iP4500 InkJet Printer
Ip4500 . . . at power up when the motor is cycling I hear something like liquid squirting out of a squeeze bottle. First page has HEAVY black line (about 1/2" wide) on back side of paper. I can see black ink leaking down inside front of printer. Printer is about 13 months old.
    Master:
  • 328 Answers
Your ink cartages got the maximum refilling change your cartages but clean the printer before installing cartages
Posted on May 27, 2011
Remove print head without power from Canon IP4500
If you have no intention of 'fixing' the one that does not power on, then just dissasemble it. If you take it apart, chances are that something will not line-up correctly when trying to re-assemble it.
To troubleshoot the power issue: I would fisrt suspect that the wall power is not getting to the power module, since, I assume, when you say both work it means you used both to run the printer with the bad print head. The power module should be deistributing the power to the rest of the printer. There will be a main circuit board that is the brains of the printer. That will need power in order to drive the print head to center when you open the top.
Dec 18, 2014 | Canon Pixma iP4500 InkJet Printer
How do I remove the front washer bottle/pump?
The motor spins one way for front washers and the other for rear washers. Yep it sits under the offside inner wing, in a gromet, in the washer bottle bottom. You will have to partly remove the plastic inner wing liner to gain access to it. Just pull the pump away from the washer bottle and dis-connect the plug. If there is any screen wash/water left in the bottle it will run up your arm. There is a small circuit in the motor that usually blows, stopping the motor working in 1 direction. It will mean a new washer pump and, yes, they are flippin expensive. JUST ONE LINE OF WISDOM HEAR. THE BIGGEST KILLER OF WASHER PUMPS IS USING WASHING UP LIQUID IN THE WASHER BOTTLE. So you better buy some propa screen wash to tight the gitz...
Sep 18, 2014 | 2007 Lexus GS 450h - All GS 450h models -...
On my 03 crown vic the a/c will not hold a charge. As I am charging the a/c I can hear it leaking
Get yourself a squirt bottle and fill with water and a few drops of dish washing liquid. if you have a way to hook a compressed air line to the low pressure tap port this will save you a bunch on freon cost, but pressurize the system and spray the area with the soap mixture and this will pinpoint the leak. The usual cause is old and shrunken o-rings at the pipe fittings, but can be a crack in a pipe, or accumulator, or evaporator core, or condenser, or even from the compressor itself.
Aug 24, 2014 | Cars & Trucks
My 1986 Mercedes Benz SL 560 ,runs rough and the exhaust SMELLS very bad Nobody follows me to close . found vac hose pulled off of the pcv hose under air cleaner from the fuel regulator . put new vac...
The first thing you need to do, is clean the carbon out, which is probably limiting the power, because valves have a VERY hard time sealing with carbon caught between the intended sealing surfaces! So, get yourself a can of Seafoam, which you COULD pour in the gas tank ... but you could also put some in a trigger sprayer (such as an empty Windex bottle, or similar), and squirt it into the air intake (with the filter REMOVED), and have the motor revving up a little while you squirt the fluid in. DO NOT BREATH the exhaust when doing such operations! You could ruin your lungs and possibly your liver too! Use a breathing filter, NOT just a mask! You can get such at Harbor Freight Tools, pretty cheap ... a LOT cheaper than going to a hospital!
May 12, 2017 | Mercedes-Benz Cars & Trucks
Windshields washer wont spray
If you can hear the washer bottle motor then you know its not an electrical problem, if you can see the fluid in the lines then the best thing to do would at each connection in the hose disconnect the line and operate the washes and see if the fluid comes out (also pay attention to pressure) do this until you reach the washer nozzles. The nozzles could be blocked. now you might say that you put new lines on so the nozzles shouldn't be blocked well if you think of it the previous hose could have been partly bocked thereby stopping any **** that is at the filter on the washer motor going anywhere(most modern cars have filters on the washer motors) So by putting new lines on you have allowed the **** at the motor travel all the way to the nozzles letting them get blocked.
Hope this helps.
Feb 23, 2012 | 1991 Suzuki Sidekick
I plug in the 6 gallon air compressor and it starts filling up then i hear an air leak but can't determan where it is located at but the machine does nor shut off because it will never full to maximum...
Mix several tablespoon full of liquid dish soap with water and put it in a spray bottle, then squirt all the piping joints. If there is a leak you will see lots of bubles.
Dec 13, 2010 | Bosch Air Tools & Compressors
The windshield washer will not squirt fluid out when i hit the button, & it has fluid in the bottle.
I would check the lines or the tips where the fluid comes out of. Also if you hit the button and you do not hear the hum or the motor work check the connection and wiring, If all is fine with the connection and wiring you could have a bad motor.
Mar 30, 2010 | 1989 Ford Ranger
Windshield Washer Pump Works But No Fluid Flow
May be the resevoir bottle may have something stuck in it, you are right, you may have a clogged line. Also check the routing of the hoses to the squirt that they are not pinched or kinked. Any washer fuild leaking anywhere?
Mar 13, 2010 | 1998 Mitsubishi Montero Sport
Engine misfire and Service light on
Start the car take a squirt bottle of water and squirt the coil to see if it starts to miss again or see sparks jump.
Aug 01, 2009 | 2002 GMC Envoy
Misfire at 4000 RPM
you may be in need of a tune up. Try squirting some wate (with a squirt bottle not a hose) an look for arcing, aslo squirt around the coil, you should eather see or hear thedifferanceonce they are et.
Jul 21, 2009 | 2001 Pontiac Grand Prix
Canon Pixma iP4500 InkJet Printer Logo
134 people viewed this question
old marine
old marine
