Hi there ken1943363
check your carby for obstructions to air bleeds and jets , clean carby out and check fuel needle valve it may be sticking ? check grounding wire from coil to switch it could be grounding intermttantly ?
could also be a ignition armature going o/c when hot or a tank breather is not venting causing a vacuum loc in tank - check this 1st , then check out ignition armature 2nd
may need to place a ignition spark tester in line with ht lead and plug, re-run machine and see if coil is going o/c when unit gets hot , as before you will soon see
once you know if its the coil , replace it and reset air gap and you should be good to
cheers pauly46
