Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
My TE 450 worked fine for 2 years and when I tried to start it this year it does nothing. Does it have a fuel filter or something else I should check?
    President:
  • Poulan Master
  • 1,545 Answers
Typically on these machines, it is the carburetor that causes most of the problems. Along with deteriorated fuel lines, carbon build up and some other 2 stroke issues. The ethanol that is added to our gas nowadays is one of the biggest culprits. Our machines ran FINE without it and no small engine likes it. It is damaging and not necessary. Your machine has to HAVE these things to Start and to Run 1. Compression (around at least 90 PSI on a 2 stroke like yours) 2. Clean Air
3. Strong Spark 4. Correct Fuel Mixture (fresh, not over 30 days old). All of these work in unison and are even MORE important for a smaller engine because any problem with ANY of these things negatively affects the performance of the machine. The carburetor is very touchy and temperamental. The least little dirt or gum and varnish can lead to a no-start condition. A carburetor that is in bad need of an adjustment can also cause this.
We can try "coaxing" the machine into running. Remove the air filter. Get a can of spray carb/choke cleaner (auto parts store). Open the choke on the carb. Open the throttle all the way. Spray a couple of good shots of the cleaner thru the throat of the carburetor. Immediately choke it and attempt to start it. Try this a couple of times. If the engine "pops", then that is a good start. If you can entice it to start running it will draw the fresh fuel you put in it (right?) from the carburetor and run. Further carb adjustments may be needed if and when you get it running.
Or if you prefer, remove, disassemble and clean the carburetor. It is a great learning experience and not that hard. As far as checking your fuel filter, it is in the fuel tank and kind of hard to see, so, you check it by observing if the MAIN fuel line from the tank is allowing fuel to flow to the carburetor, The primer/purge bulb assists in this matter and ethanol destroys it too. Very small check valves in the carb help keep the fuel flowing in the right direction. When they fail, ( I have one now doing this), the fuel flows backwards, the engine floods and it won't start at all.
Posted on May 28, 2011
Testimonial: "Thank you"
  • Roy Cagle
    Roy Cagle May 28, 2011
    You are certainly welcome. They have inexpensive carburetor rebuild kits for these machines. They usually restore the machine to run again. They have a gasket and diaphragm kit (because those parts dry out and get deteriorated from ethanol), and they also have a complete rebuild kit for these little carbs. The complete kit costs a little more and you can usually get away with just the G & D kit (gasket and diaphragm). Rebuilding one isn't hard, fairly interesting, and hey...you just might learn something in the process. There are plenty of videos and pictures and diagrams available on how to do this. Post back if you are intererested,or post anytime. We will see your comment and reply. And again, you're welcome.
Fuel filter location
1998 Nissan/Datsun 200SX 1.6L SFI DOHC 4cyl
The Fuel Filter is located: Under hood, driver side, rear engine area, passenger side of master cylinder, mounted in fuel line,just guessed at your year,
Feb 10, 2014 | Nissan 200SX Cars & Trucks
Car not starting
Could be the fuel filter. When the vehicle used all the fuel in the tank, it may have sucked in some trash on the bottom of the tank. There is almost always some in there. You may need to replace the fuel filter and try to start the car again.
Nov 12, 2012 | Fiat Cars & Trucks
Bolen 17HP riding mower tries to start with key in off position
It sounds like you have an ign. wire grounded or your ign switch has a short in it. Also remove the cover on your starter drive to be sure it has released.
Apr 30, 2010 | Garden
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Heter trys to ignite,replaced igniter,cleaned fuel filter
1. Check the ignition transformer. It may be grounded,
or it could be defective, and need to be replaced.
2. You have already replace the igniter and the
photoeye.
3. Once the ignition transformer works, everything will
be alright.
May this tip help you.
Jan 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel filter nipple broke
get some proof in writing from the retailer noting the issue for future ref.
Feb 03, 2009 | 2008 Husqvarna TE 450
Te 450 2004 - won't start
verify spark - fuel - air
Jan 29, 2009 | 2004 Husqvarna TE 450
Hard starting
sounds like u may need a new fuel filter...you may be getting water in your gas so id apply a bottle of heet as well
Oct 28, 2008 | 1999 Mercury Grand Marquis
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
325 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
