Question about Gateway FPD1975 19" LCD Monitor
Does not turn on
Sometimes the monitor will not turn on. The light is not on but it feels like the monitor is running. If I squeeze the monitor itself sometimes it will then turn on.
  • Gateway Master
  • 5,569 Answers
That sounds like sloppy manufacturing, perhaps what we call a 'cold solder joint.' These will often respond to mechanical movement that temporarily causes the bad joint to contact.
These can be kind of tough to find and the condition will probably not go away without being cured.
Posted on Aug 16, 2008
SOURCE:
How do i fix a monitor that sometimes just turn off by itself and turn on after being cut of the elec. power?
There are settings for the sleep (power saving) modes that came with Windows updates.
Some of our monitors also shut off the power indicator light when they go to sleep.
Solution: Check the power saving settings in Windows.
Jul 22, 2015 | Computers & Internet
The main menu keeps on popping up and sets itself. It drives me crazy. What do we need to do to fix the issue?
Hi!
Without getting more information on your issue, what I suggest is for you to do a hard monitor reset. To do so unplug the monitor and hold down the monitor's power button for 30 seconds without letting go. Plug the monitor back in and see how it works.
Also, the problem could be with a faulty physical contact on the monitor itself, check each button on the monitor for a depression and release "feel". Sometimes these buttons go bad.
Hope I helped!
Mar 01, 2011 | HP 2009M Monitor
The cuff squeezes my arm too much and it hurts. The reading is way too high everytime. I don't know how to adjust it.
do not inflate the cuff too much. if you know your usual blood pressure, just add about 5-10 mmHg when you inflate it so that you won't hurt yourself. for example, if your BP is usually 130/90, squeeze the cuff to 135-140 only. but if you doubt that your BP is way much higher than that by assessing on what you are feeling, just do not squeeze the cuff further than 200.
Jan 21, 2011 | Life Fitness Ultra Blood Pressure Monitor...
When I turn the Tv on the green light shows power and the Tv squeeze 3 times every 3 sec. with no picture, then the turn turn off.
hello my name is rico, i work on tvs sometimes, it looks like you have bad cold solder in your power supply and you keep trying to power it on you will damage your tv, if you need help to get fix let me know feel free to call at 602-810-7149 anytime
Dec 29, 2010 | RCA Televison & Video
The squeeze bulb will not pump up. Can't use the monitor.
make sure the little knob isnt all the way open, sometimes if its all the way open its hard to turn, making you think its closed
Oct 22, 2010 | Sunbeam Digital Blood Pressure Monitor
Squeeze bulb needs replacement. Where can I get one.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 22, 2009 | Sunbeam Digital Blood Pressure Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
How tight should I put it on my wrist and should it give me one squeeze or several before releasing
Up to about 160mm for average blood pressure-up to 210mm for elevated Blood pressure. As the pressure lets down it will squeeze several times as it calibrates itself. Hope this helps.
Dec 25, 2008 | Samsung Healthy Living Deluxe Wrist Blood...
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Gateway FPD1975 19" LCD Monitor Logo
145 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
