Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
2 hp b&s rngine runs 20 secs. and dies - Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
  • Briggs & Str... Master
  • 7,482 Answers
Hi mowertools...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
Toyota avensis 1az will start but only runs for about 20-30 sec then dies but then to start it again and it starts for about 20-30 sec and dies again
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 24, 2017 | Toyota Cars & Trucks
How can i unlock my tablet
Perform a factory reset instrutions in back of hand book.
Aug 23, 2014 | Tablets & eReaders
Password forgot unlock
whenever you forget your password you can use your google account to reset it or you send it to a technician for flashing
Nov 06, 2013 | ViewSonic VPAD7 ANDROID 22 TABLET WGMS...
Stihl 280 runs for 20 secs then dies
Sounds like a fueling problem, Check carb, fuel line and tank vent.
Mar 26, 2013 | Stihl Ms280 Dust Cover W/ Screws 280 270...
"Stability Control Fail" light on.
first job is to check the part load and main beather hoses are ok the stability system light may be a false indicator if the engine has stalled best is to get fault codes out of the ecm with a code reader to help but air leaks on the engine inlet side can cause strange/seeming unrelated symptoms
Aug 22, 2017 | 1997 Jaguar XK8
Morrison 1400W electric lawn mower goes for 20 secs.
I would think that switch may be faulty? Or is it a momentary switch only?, if so, then you have an input to the controller problem, insomuch as it starts, runs, for some reason thinks there is a problem & shuts down, whereby the switch is being pressed, so it "Sees" this and starts again, and so on?
Mar 04, 2010 | Garden
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
Jun 22, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
184 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
