Question about 2wire (2701HG-B) Wireless Router
Two laptops sitting side by side-one will connect to 2wire router and the other one won't-both running windows 7
  • 984 Answers
Let's see if I can help you.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
Posted on May 27, 2011
My 2WIRE router won't give out wireless signal.
Unplug the ISP modem and the 2wire, Check ALL cables and reseat connections, plug in the ISP modem, wait for selftest, plug in wireless, wait for selftest, does your wireless SSID show in Available Wireless Networks on the Laptop? Can you connect using a Ethernet cable to verify it's getting a signal? Contact your ISP and have them verify the signal, have a ISP tech come out to analize the signal, it may be outside?
Feb 07, 2013 | 2wire Computers & Internet
Windows 7 driver
No driver needed since it does not need to be installed into Windows. Connect the ISP modem to the main port. DSL or Network port, depending on your service. Then connect your PC to any other port. That's it!.
To adminstrate. Open a web browser and go to 192.168.1.254 Alternate Admin URL: http://gateway.2wire.net/setup/
There is a small reset hole if it already has a password. Hold it in till it cycles. This will clear any custom settings/
http://support.2wire.com/
http://www.2wire.com/pages/pdfs/106.pdf
Oct 20, 2012 | 2wire 1800HG Router (RG1800HG00)
New download of windows 7 won't retain or create internet connectins
Ok, this is conflicting... won't retain or create!! Doesn't it have to be created to retain it?
Did it connect before you downloaded windows 7? Exactly what happens when you try to get on the internet? Do you have the wireless switch on the laptop turned on? Do you see your wireless router? If so did you put the password in correctly? If not, it will never connect.
Jun 03, 2012 | Compaq Presario CQ62231NR Notebook
I am connected to the internet but through the ethernet cable. The wireless on the modem isn't working. My laptop wireless is but i cant connect without my cable. Please help :)
Wireless light ont he modem would only lit up once a device had succesfully connected to it:
what is the operating system of your laptop?
you can also Try this links: complete walkthrough and screenshot is in the link... thanks...
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
if your with AT&T try calling this number
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 08, 2011 | 2wire (2701HG-B) Wireless Router
I want to know if my 2wire 2701HG-B supports WPS or AOSS? I'm trying to connect my laptop to my wireless printer but it goes through a Wireless Network which is my 2wire router obviously. If my router...
As long as you do not have your laptop set up on teh 2701HG-B's DMZ everything should work. I have the 2701HGV-B, almost the same except my can do VoIP, and I have my laptop running wirelessly and I can connect to the network printer.
Make sure the printer has a static IP address for your local LAN, which should be in the 192.168.X.X scope, or the printer will change IP addresses every time it resets and that will cause you to lose connection to it from the laptop.
As for WPS, there should be a sticker on the side of teh 2-Wire that has a 6 digital key number, all numbers no letters, that will be the WPS key.
Hope that helps.
Jun 04, 2011 | 2wire (2701HG-B) Wireless Router
Hello, I have an At&t 2wire router and will not connect to my laptop....the wireless green light does not blink and cannot connect..
Wireless light will only lit up if there is a device that is wirelessly connected to your 2wire router ------------------
try checking this links:
check the links out
and if referring about the network key:
2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key.
If you have questions please let me know. Thanks
Apr 16, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Im trying to connect my laptop to the router,(the laptop is an hp pavilion running on windows 7, and the router is a 2wire) but I cant connect to the router and theres no option 2 put in the WEP key. (And...
Your class geek is not much of a geek. The computer can loose the wireless settings quite commonly. Open the wireless connection window as below:
right-click the network you are trying to connect to and click properties and then the security tab. You should get this window:
Change the encryption type to WEP and enter your router's WEP key. Click OK and you should be able to connect. OK?
Dec 05, 2010 | HP Pavilion dv6000z Notebook
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
You can check the passphrase when you access the router page:
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
Thanks for using Fixya.
May 13, 2010 | Computers & Internet
2wire portal router, after year of wireless connect, stopped
it could be that the wireless part of the unit has failed but to test, can you make sure and try while sitting very close? Also, check for any new appliances close by causing interference
Jul 08, 2009 | 2wire HomePortal® 1800HW Router...
2wire (2701HG-B) Wireless Router Logo
192 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
