Question about Dryers
My kenmore series 80 gas dryer, mod # 110 72842101 will run but will not heat. It was fine last weekend and is not fine now. Is there a pilot light on this thing that may have gone out?
  • 1 more comment
  • caseymarcrof May 27, 2011
    oh Kevin, I think this is too scary for me. I cleaned the vent, and checked it outside the house as well - still no heat. I guess I will call for repair. thanks for trying.
    Kevin - the kenmore again, why would a thermostat go out? there was no time of sort of bad running, no suspicious smells, no indication that anything was going wrong until it did. just asking.
    i guess, in that it defined a next step in solving the problem - calling a repair person. I kind of knew I was out of my depth anyway. thanks!
  • Dryers Master
  • 1,902 Answers
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermostat. When the thermostat goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if thermostat reads continuity then please get back to me if you have any other questions.
Kevin
Posted on May 27, 2011
  • Kevin White
    Kevin White May 27, 2011
    This is a common problem that occurs in dryer after few years.
2 Suggested Answers
  • 3074 Answers
SOURCE: my kenmore series 80 gas
http://www.applianceaid.com/gas_dryer.html#noheat
Kenmore 80 series gas dryer- 110 72842100 Dryer runs but the heat is not working? Do not hear gas igniting to create the heat, does this dryer have a pilot that went out?
Their is a flame sensor, an ignitor, and a pair of coils all wired together into one assembly.
Here is the heat control and duct fuse: themobilian_2068.jpg
Check that fuse next to that control. If it is open the dryer gas assembly won't get any power.
Manual and more good stuff HERE
Mar 27, 2011 | Kenmore Dryers
Light pilot light on kenmore 80 series gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Kenmore Dryers
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Dryer no heating up
defective thermal fuse ,,replace
Dec 13, 2008 | Kenmore 72802 Gas Dryer
How to light the pilot?
If this is an electric dryer, it doesn't have a pilot either. If this is a gas dryer it will have an electric pilot. but then if it were a gas dryer, it would have a removable lower front panel for servicing the burner. So you must have an electric dryer. if the dryer runs but does not heat, the electric element is most likely at fault. If you really were looking for a pilot light on an electric dryer, I must recommend that you call a reputable appliance service regarding repairs so as to not jeopardize your safety.
Aug 31, 2008 | Kenmore 84052 Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
