Question about Lexmark Office Equipment & Supplies
Screen reading clear the carrier jam.when push the select button printer makes banging sound. please help tell me what to do thanks dee
  • richard999 Oct 02, 2008
    exactly the same problem, "carrier jam" and cartridges slam to the left and back every time powered on - anyone fixed it?
  • bradleybear Jan 28, 2009
    i bought mine off hsn. third time using it and now it does that, carrier jam and loud banging sound lexmark x5495 purchased 11-2008
    Master:
  • 377 Answers
TRY TO TEST AND CHECK THE PRINTER ON THE OTHER PC.. TO TEST IF A VIRUS WAS CONTROLLING THIS PROBLEM..
Posted on Aug 16, 2008
I HAVE THE DELL 924, which KEEPS SAYING CLEAR CARRIER JAM AND MAKING a loud banging sound, BUT there is NoTHING BLOCKING IT. WhAT CAN I DO to fix the problem?
THE HOME POSITION SENSOR OR CARRAIGE ENCODER MOTOR IS BAD. IF UNDER WARRANTY, CONTACT DELL FOR REPAIR/REPLACEMENT. IF NO, A NEW ONE AT SUPERWAREHOUSE.COM IS MORE ECONOMICAL THAN A REPAIR. THANKS
Jan 08, 2011 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Clear the carrier jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Lexmark P4350 All-In-One InkJet Printer
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Error 1200 indicates paper jamming. No paper is jammed however the cartridge carrier appears to be jammed on the left hand side. I have tried everything I can find but cannot release it. Even uninstalling...
The error 1200 indicates that the cartridge carrier is stuck inside the printer. Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridges are in the middle, snap them firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
You should then try to self-test the printer. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in and follow these steps:
Next, try this printer self-test by following the steps given below:
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
"Clear the carrier jam" on DELL Printer 926
could something be stuck in the printer? clip/ paper/ dust
might be that simple!
Jan 24, 2009 | Dell 926 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
eventually I uninstalled it then re installed it and thank god it solved the problem ididnt know it was that easy
Jan 16, 2009 | Dell 926 All-In-One InkJet Printer
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier Jam
I loaded to new cartridges into the printer1.gif, switched it on, cartrigde went from one side to the other with a bang, error on printer reads, clear the carrier jam, cn you help?
ed
Jan 11, 2008 | Lexmark OfficeCenter X3350 All-in-One...
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
