Question about Cycling
I have a huffy cave creek 21 gripshift bike w. shimano components and need instructions how the gears work
  • 1 more comment
  • susanjorg May 28, 2011
    I don't want to replace anything; I want to know how to use the gears ie how do you shift gears?
    Yes. I understand what to do. As a beginner It would have been more helpful if someone outlined what the different gears do ie is a higher gear for uphill grades and the lower ones for downhill grades. For the price I paid for my original question, I would have thought that would be included.
    Thank you! That was very helpful. At least I have a starting point.
  • 776 Answers
Trying to fix the module on the grip-shift is always a waste of time. The best thing to do is replace the shifter.
The shifter pulls the cable tight toward the shifter and uses a rachet mechanism to insure the chain is always in alignment under one gear and does not fall between two gears (like the original multi-sproket bikes from the 1970''s and 80s).
The derailer near the sproket has a spring to pull the cable back for the smaller diameter gears when the shifter is turned the other way.
The light-weight pastic gears and rachet mechanism in the twist grip tend to strip and fail. The small plastic gears are not available as replacement parts except for the highest end shifters (trigger shifters). The twist shifters are considered low-end to mid-range and replacement parts were never available that I remember.
To replace the twist grip, make notes how the cable routes to the corresponding derailer. Detach the cable near the derailer and pull it through to the shifter. Remove the shifter from the handgrip. Pullt he cable through. Pull the cable though the new shifter and mount it onto the handgrip. Route the cable through the rest of the frame as needed (see notes you made earlier). Adjust the cable to just tight enough to keep the derailer above the sproket indicated on the shifter. You may need a pair of locking pliers to hold the cable tight before locking downt the nut on the derailer. There is a fine adjustment screw on the derailer to make final adjustments if needed (they usually are).
Shifters are available at most bicylce stores. You can also find many fairly new bikes on craiglist that you can strip for parts (as little as $25 for the bike). Sometimes they are given away for free on craigslist and you may find an exact replacment - we did!).
Shifters from the bike shops cost $20 to $50 for a Huffy (depending on the bike store).
Good luck, I hope I understood what you wanted from your question.
-Mark
Posted on May 28, 2011
  • Mark T
    Mark T May 28, 2011
    Sorry for the misunderstanding.
    To shift, just peddle and twist the grip firmly but not too quickly. Make sure you are peddling or you will only stretch/stress the cables and not change gears.
    The idea is to keep your legs moving at a near constant rpm (revolutions per minute). 70 rpm is reasonable for warm ups (first mile) and 50 to 60rpm for regular riding. For a beginner,you can set the front gear (with your left hand) to the middle sprocket. Then use the right hand shifter as your main control when you ride (change back sprockets). Shifting (changing sprockets) allows you to keep putting the same leg power into the ride while controlling power to the back wheel for speed (small back sprocket for going down hills fast) or power (large back sprocket for going up hills). use the sprockets in the middle for flat an light hills. You don't have to watch which sprocket you are on, just shift until your peddle speed is in you comfort zone.
    Remember, you don't want the gears "too tall" were your rpms are too low (less than 20 or 30) because it will be bad for your knees because it takes a lot of stress. Most new rides just forget to shift. Stay focused and the more time you can keep it in the comfort range (50 rpms), the more comfortable your ride will be.
    Good luck and have fun.
    -Mark
  • Mark T
    Mark T May 28, 2011
    in general, the higher numbers on your twist shifters make it more difficult to pedal but you will go further with each pedal (This is good for flat or down hill).
    The lower numbers on the twist grip are better for hills. There is no right or wrong gear for you, however becasue it is very dependent on the terrain you are driving on, your skill level and your level of conditioning & strength.
How do I adjust 7 speed shimano on Huffy?
Cable adjustment is complex. Suggest taking your bike to local bike shop for assistance
Sep 08, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
I have a late 70's huffy saratoga bike that came
All you have to do is put a distilled version of your request into a search engine "adjust shimano 3 speed internal hub" and voila - videos and other resources.
http://www.parktool.com/blog/repair-help/internal-gear-hubs
Jul 11, 2011 | Cycling
I've pulled my raleigh shimano 21 bicycle apart and I've forgotten how to put it back together
"Shimano 21" doesn't really narrow it down much.
What exactly are you needing instructions for? Most bikes are just static frames with a bunch of aftermarket (Shimano, for example) stuff hung on them.
Everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Google will find tons of How-to videos for assembly and adjustment.
You might find a Raleigh-specific manual for your bike here...
http://www.raleighusa.com/downloads/
Apr 26, 2011 | Shimano Cycling
Is there a web sit e or other material i can get on the cranbrook beach cruiser what i need is a detailed explantion on removing and insalling the rear hub with a coaster brake assembly
Most bikes are just static frames with a bunch of aftermarket stuff hung on them.
Everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the manufacturers' websites.
Google will find tons of How-to videos.
If it's Shimano try http://techdocs.shimano.com/techdocs/index.jsp
Apr 01, 2011 | Huffy Cycling
My huffy triton 26 18 speed bike will not select any of the 3 main gears the derailer does not move when you try to select gears. all back gearing works fine. the gearing system on the bike is a shimano...
The problem has nothing to do with the derailleur itself. Either your shift cable has stretched and is now too loose (in which case the shifter will move but have no effect on derailleur movement), the cable/housing is rusted (in which case the lever will usually not move at all), or the lever is broken or gummed up (in which case it will move, but you will get no clicks). Each problem has a separate solution. Either take to a bike co-op for help in fixing it, to a bike shop to have them estimate and repair it, or go to a site like Park Tool's Repair Help and learn how to fix it. It's very difficult to instruct you with just words, and good options are already available.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 24, 2017 | Cycling
What kind of components do I need?
Most bikes have Shimano shifters & deraillers; SRAM is the other main vendor. Shimano makes a wide range; the following table attempts to describe these and presents my best guess of where the SRAM line fits in: Model Quality SRAM Equivalent?
SIS, Tourney (or just says Shimano) Mainly designed for riding around the neighborhood
Altus Sufficient for paved or very easy trails; avoid hills 3.0
Acera Slightly better, but won't shift well under stress; capable for easy casual riding 4.0
Alivio Minimal capable for recreational riding; will handle some hard riding 5.0
STX / Deore Entry-level components for hard riding; tough & reliable 7.0
LX The minimum standard for hard riding. Reliable & responsive 9.0
XT More responsive than LX, but still reasonable tough 9.0SL
XTR Light, responsive racing components; tend to be quite expensive; often sacrifices toughness for responsiveness X.0
Look for a component set that fits your expected riding style.
Note:The numbered SRAM components aren't compatible with Shimano components. SRAM does make grip-shifters that are Shimano-compatible.
There are many other manufacturers that specialize in various components (Avid, Cane Creek, Race Face, Hope) and make great ones. Ask the LBS personnel for a comparison if you see a brand you don't know. Also, you can use the same test as forks above: if its not sold separately, its probably more questionable. If you're getting a full-suspension bike, make sure you get a good rear shock as well (it'll probably be something other than SRAM or Shimano).
Dec 16, 2010 | Cycling
I picked up an old Giant in good cond. only prob. is the Shimano 200GS Shifters. They work but only when they want to. It's like they need to take a break after a few shifts. Can these be adjusted ? Or...
Take it in for service, probably has stretched cables and need to readjusted. It will be worth it to get a tuneup because Giant is a bike shop quality bike, not a discount house special. Treat it right and it will last you a long time.
Sep 13, 2010 | Cycling
Shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Nov 21, 2009 | Cycling
Operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Jul 15, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Cycling Logo
218 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
