My LP130 wont show my computer screen, i think its all hooked up right. Bulb fine.
  • 1,116 Answers
Activate the external screen connector on your computer. If you are in windows, go to Start - Control Panel - Display and you should see two displays connected to the computer. Set the computer to CLONE the internal display and you should now see the second display on your screen. If this does not work, please tell me you Computer make and model as well as you operating system and I will walk you through the setup for the hot-key that activates your display.
Posted on May 27, 2011
Why does my hp m6-1035dx have a Black screen after start-up?
You're on the right track and probably resolved the problem by now, it's what I would of been looking at as well seeing it works fine when connected toan external Monitor.
Cheers.
Sep 03, 2014 | HP M6-1035DX 15.6 Laptop A10 X4 2.3G6GB...
Screen flickers and color wont show
What kind of cable are you using, and how long is it? Does it work for connecting the PC to a monitor? And are there any splitters on the line?
Jan 30, 2014 | Hitachi CP-X253 Projector
How do you remove the top cover off on a InFocus LP130
Here is how you dismantle the LP130, I did a screen capture for you can see it:
Mar 14, 2011 | InFocus LP 130 Multimedia Projector
Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Mar 03, 2010 | InFocus Office Equipment & Supplies
In-Focus LP-130 and it turns on but the lamp wont fire up, it sounds like the cooling fan goes on and then stops, its a brand new bulb also.. some one said its daughter board that controls the cooling lamp...
the ballast is bad. the fan turns on for the colorwheel, but when the lamp doesn't strike, the fan and colorwheel turn off until it tries again. unfortunately, there are no replacement parts for the lp130.
Jul 17, 2009 | InFocus Office Equipment & Supplies
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
LP130 projector - no light from lamp
there are several other issue that can arise with this unit
you may want to check out fixmyprojector.com
Jun 30, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
k24674
