Question about Compaq Presario M2000 Notebook
Compac presario m2000. problems with recovery disk. It will boot from cd, but it gives no options, it starts loading windows. after about 5 min. it says setup is starting windows, but that is as far as it goes. it freezes.
  • 2,632 Answers
Welcome to Fixya. The issue can be caused by a bad Memory Module or RAM. If you have a spare working memory or ram that you can use it would be better or If you can Reseat the ram if you don't have a replacement yet and try it if it will work.
If you have questions please let me know. Thanks for using Fixya
Posted on May 27, 2011
I have installed ubuntu in drive C(66gb) with windows xp,giving 13 gb space to ubuntu and rest to xp .now i have deleted the disk partition for ubuntu of 13 gb .when i start computer it shows grub error-17...
when this happened to me on my Vista machine last year, I freaked out until I accidentally fixed it using by booting with my original Vista boot disc, and choosing 'Repair OS'. Try finding a/your original Windows XP install disc and seeing if it will repair and replace your own Windows boot sector. It would be best to find the one that came with your system, or another like it, but if all else fails, just try a hologrammed Windows XP install CD, but instead of 'install', choose 'repair'.
Feb 15, 2011 | Compaq Presario M2000 Notebook
Will not load to login window
if you know that it has a recovery partition on the hdd try to reinstall the windows cause it sounds to me like a damaged windows.. to do that try to press F11 on start and see if it has a recovery partition to reinstall from ...if not try with a bootable windows disk ...
If the boot order is not set to boot from cd first and its is not asking to press any key to boot from cd ..than you should insert the disk and choose from pressing at start F12 ( or F10 ) the boot device you need..and continue the installing from the disk by pressing any key to boot from cd ..
In the other matter it seams that someone (probably the last guy that installed it ) messed around and inserted a Bios password to make sure you will call him again the next time it breaks..This matter is only avoidable by opening it and removing the Bios battery to default the Bios settings ..
Jun 28, 2010 | Compaq Presario M2000 Notebook
My presario won't load windows. I have tried going to safe mode with command prompt in advanced option menu and I can't get to the command window to type in: c and then %systemroot%system32 estore...
Insert the first disk from the Recovery set, and restart the computer. Force it to "boot" from the CD-ROM device, rather than booting from the 'C:' disk-drive.
That should start the reinstallation of Windows.
Jun 24, 2010 | HP Compaq Presario SR1303wm PC Desktop
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
I have another computer that won't start. the screen says - missing \windows\systems32\config\system use original setup cd rom select r to start repair I tried but it doesn't work
you need bootable windows disk or recovery disk.
Then set first boot device as your cd or dvd rom.
when you power up the computer press F1 or F2 or "del" key to enter in bios then go to boot option then save settings.
thenh put cd in cd /dvd rom then it boot with disk.
Then it load some file wait for 5-7 minutes then it gives screen then press enter.
then followe the instuction.
Aug 08, 2009 | Computers & Internet
I have compaq pc presario c300 i cant open windows meaning when i start up my laptop the xp window is just come n go faster (popUp)
When you boot up press F8 function key and Windows will give a list of boot options, select Last Known Good Configuration and hopefully Windows will start up correctly. If not boot up again, press F8 and select Safe Mode and Windows should boot up in standard VGA display mode.
If this doesn't work you need the Compac restore CD disk that came with your laptop. Boot up with this CD to restore your laptop, you most likely will lose data.
Jul 29, 2009 | HP Compaq Presario C304NR Notebook
Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
Jan 28, 2008 | Compaq Presario M2000 Notebook
Computer will not boot
Chances are if you load the windows CD into the CD player it wil boot to the CD. You can opt to repair the current version of windows without a format. You will not loose your data.
Jan 02, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario M2000 Notebook Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
