Question about GE Refrigerators
GE Refrigerator Problem
I have a GE refrigerator model #GSS22SGPA SS. The problem is the bottom of the freezer is normal cold and keeps everything frozen same with the refrigerator side, everything on the bottom is staying cool. However the top of the freezer and fridge is warm.
I have taken the back panel off and it wasn't that dirty around what I think is the condensor and the fan was working properly. I then removed the back panel inside the freezer and the coils have varying degrees of frost on them. The top of the coils tend to have a heavy frost while the ones on the bottom have a light to medium coating of frost. Also I hear like a morris code buzzing/humming sound. I do not see a fan in there, but maybe it's because I haven't taken out the ice maker covering panels off??
So do you have any solutions to my problem? I would appreciate any help.
  • 2,920 Answers
You have a leak in the freon line
Posted on Aug 16, 2008
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
My ge fridg model PDS20MBSWW has a problem: many times a day it make a clicking noise the control light goes out and after 30 minutes everything return to normal can you help thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
May 21, 2011 | GE Profile PDS20MBSWW 30" 19.5 Cu. Ft....
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Mar 28, 2011 | GE Refrigerators
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Dec 26, 2010 | Refrigerators
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
GE side by side and it is not keeping the refrigerator cold
You have a fan not working. The fan moves cold air from the freezer side to the refg. side. eather the fan is bad or the T-stat. You will have to pull down your controls and ck wiring with a Volt meter.
Aug 04, 2009 | Refrigerators
Defrost Timer
Hi: It is your defrost heater most likely. If not the defrost timer. The heater is in the bottom of your freezer behind the metal panel. Next time you defrost it remove the panel and inspect it. It's a glass tube with a metal coil (filament) running through it. If the coil is broken replace it. If not look into a defrost timer. The parts will be shown on with a diagram. I hope this helps. Jeff
Jun 08, 2009 | GE GSH25SGPSS Side by Side Refrigerator
Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Jun 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Refrigerators Logo
314 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
