Question about Lexmark X4875 All-In-One InkJet Printer
How do I turn print on both sides of paper on and off
  • Official Brand Answer
  • 3,344 Answers
The Lexmark X4850-X4875 User's Guide can show you the step-by-step instructions on how to use the 2-sided printing function.(go to page 54)
Posted on Jun 01, 2011
Testimonial: "Great solution. Thank you."
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
My manual was in a strange language. How do I
Your manual can be found here.
Printing on both sides of paper You can print on both sides of a paper; duplex. Before printing, decide how you want your document oriented. You can only use this feature with Letter, Legal, A4, US Folio, or Oficio sized paper.
Do not print on both sides of the special media, such as labels, envelopes, or thick paper to print on both sides of paper. It may cause a paper jam or damage the machine.
  1. To change the print settings from your software application, access Printing Preferences. (See Opening Printing Preferences.)
  2. Click the Layout tab.
  3. From the Double-sided Printing section, select the binding option you want.
    • Printer Default: If you select this option, this feature is determined by the setting you’ve made on the control panel of the machine.
    • None
    • Long Edge: This option is the conventional layout used in bookbinding.
    • Short Edge: This option is the conventional layout used in calendars.
    • Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing.
  4. Click the Paper tab, select the Paper Options.
  5. Click OK or Print until you exit the Print window.
If your machine does not have a duplex unit, you should complete the printing job manually. The machine prints every other page of the document first. After that , a message appears on your computer. Follow the on-screen instructions to complete the printing job.
Good Luck!
Jesse
Jan 06, 2010 | Samsung ML-2855ND Laser Printer
Lbp5000 two sides print
LBP5000 doesn't have a duplexer for automatic double sided printing, so it's maual duplex.
You have to print on one side, then put the paper in the paper tray again. Take note of the pictogram that shows a printed page with the corner turned over, this indicates wich way you put the paper in (for the print you are about to make, not what is already on the paper)
Dec 09, 2009 | Canon LASER SHOT LBP-5000 Printer
My duplex printer prints the second page(inside) of a half- fold card upside down. The printer wizard from orintmaster and printshop is designed for single- pass printers si that doesn't work... In fact,...
actually the gears in the printer are got worn out or some thing is blocking the gears so its not able to turn the paper internally to print on the right part of paper.and its printing upside down.remove the cartridge from the printer.and apply air blower in the inner area of printer.remove all the dust collected in the printer by blowing air everywhere in the printer.then check out if still the same problem the paper sliding gears needs to be replaced.you can get the gear assembly for local printer repair shop.they also help if replacing the gear assembly.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya
Oct 02, 2009 | Brother HL 5250DN Laser Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Prints one side fine turn paper over to print other side and it twists paper sidways and tears it in half.
Hi. It's hard to say without more details, but two things come up quickly to mind. 1) is the paper only meant to be printed on one side? Some are, and should indicate so (i.e. 'load this side up'). 2) the paper is goofed up (bent, flexed, twisted, loosened up, etc.) by the first printing and therefore is getting jammed.
I'd suggest changing brand of paper and / or be very careful loading, as this seems like a pretty regular paper jam situation.
Aug 06, 2009 | Office Equipment & Supplies
I have a Canon mx310 printer. I have read the book but can't find out if I can print on both sides of a piece of paper. If it can be done can you explain how Regards Ted gray
I just read the data on your model and it says nothing about two sided printing.
You can still print two sides of the paper with any printer. Save page 1 and page two sweperately. Either place one piece of paper into your printer or if it feeds for the front of the pile ,Just have it print side on. After that is done the the printed paper and place it back into the the front of the paper tray so that it will be the next one printed,then print side two . A slow poocess but sometimes worth it. (You may have to turn the paper around and or backwards for it to print on the correct side in the directing you desire, experiment).
Dec 21, 2008 | Canon Office Equipment & Supplies
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark X4875 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
