Question about Magellan GPS
When you turn on the unit it brings up your current location and follow you as you drive. will not allow you to get to menu or ESC. i tried to turn off and on and unplug and re-plug but nothing changes
This did not work on my 1430. Any other suggestions?
Posted on Oct 14, 2011
  • 1 more comment
  • Ric Vargoshhe Oct 15, 2011
    I downloaded software, still the touch screen non-responsive. This GPS has never been dropped, spent most of it's life on my trucks dashboard.
  • Mike Cairns
    Mike Cairns Oct 15, 2011
    Well this obviously seems like a internal problem. I guess the next step is to contact Magellan through the link I game you, and see if there is a way you can send it in to them and most likely they will replace it more that fix it. Here is what I have done for some of my customers here locally that has helped. We called Magellan as well as wrote them a letter and really beefed it up like. Saying how you love there product and have told all your friends and they even bought one based on your referral. And not your embarrassed as, if your friends found out now yours is not working and if the company does not stand behind it, looks bad. Point is write a real professional letter with some bragging of how they great they are, the results have been about a 80% positive results. A couple customers took my advice and got a new one back and a few got there's fixed and returned all for just cost of shipping. Its worth a try, Mike
    Thanks Mike. I did send an email Thurs, no response yet, asking what I might do.
  • 3,053 Answers
Did you try when turning it on holding power button down for at least 10 seconds as it is coming on? Even though you see it coming on keep button down for about 8 to 10 seconds. This is a way of rebooting system. Let me know if that works.
Posted on May 27, 2011
  • Mike Cairns
    Mike Cairns Oct 14, 2011
    Ok if you tried the manual reboot and still stays where it was with no change, then this is a software issue. You would have to have new updates and restored. Here is the link to the actual Magellan site to do this. It tells you how and has support as well. You have to probably register it if you have not already and then do the updates via usb port from computer. Here is the link to copy and paste and put in your browser. http://www.magellangps.com/ Thanks, Mike
  • Mike Cairns
    Let me know if this works, get back to me please on results. Mike
Go back to factory settings
First, is this to reset the configuration of the laptop to default e.g CMOS, if so there are a couple of ways,
First look for a Setup option when first turning it on, e.g press Esc or Del or F10 (search the manufacturers details - e.g HP reset and ideally the model)
Second, if you are talking hard drive, this sometimes can be done through the startup menu, normally there is an option in the startup to select the method of starting. For newer versions of Windows, press F8 a few times as the computer is starting, hopefully it will bring up a menu, if this does not work, try F9 (this is the boot device menu normally).
Other options are to use a bootable media such as a CD DVD or USB or even a Floppy Disk.
Ideally the user manual for the laptop should have instructions on how to restore the computer.
If all else fails find out where the backup battery is located and disconnected it. Sometimes you need to disconnect for a long time or jumper between some connections to switch to reset.
Feb 05, 2015 | Computers & Internet
Memory full, cant delete stored favourite destinations, sat nav turns off when delete is pressed.
Hello vinny!!
Perform a hard reset to clear all your memory!!!
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. Choose "Clear Waypoints". After some time the unit should reboot.
Jul 12, 2008 | Garmin GPS
Tip
Shortcuts
Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing
on Apr 12, 2011 | Computers & Internet
LCD display is fading
Run self test and LCD test:
Power unit on while holding MENU/ESC-
press down arrow to TEST then right arrow to start.
When self test is complete use down arrow to go to LCD TEST, then right arrow to start. Press MENU/ESC for a while screen the MENU/ESC again for vertical gray bars. Press MENU/ESC 3 times to exit. The LCD unit is pn 000-145-512, $175. I strongly suggest you not attempt replacing the LCD yourself unless you are a qualified Furuno tech.
Feb 14, 2013 | Furuno 1623 Radar 16nm Range
My 2009 Hyundai Sonata quit accelerating while driving in town. The ESC and check engine light came on. I was able to turn the car off and back on and the ESC light went off and acceleration worked...
This may not be your problem but it does bring the vehicle in fail safe you may have a warranty
Group TRANSAXLE
Number 09-AT-016
Date AUGUST, 2009
Model
1999-SONATA
2001-ELANTRA, SANTA FE & XG
2003-TIBURON
2005-TUCSON
2006-AZERA
2007-ENTOURAGE
Subject
AUTOMATIC TRANSAXLE DIAGNOSTIC TROUBLE CODES P0715, P0716, P0717, P0720, P0721 & P0722
An improperly functioning input speed sensor or output speed sensor may result in the following conditions:
^ "Check Engine" light on
^ Harsh P-R or P-D engagement shock
^ Transaxle in 3rd gear fail-safe
^ Diagnostic trouble codes 1. Using a GDS, check for DTCs in both the "Engine" and "Automatic Transaxle" menus. Record the DTC and description.
2. From the GDS, select:
^ Vehicle
^ "Auto Transaxle" menu
^ "Current Data"
^ "Input speed sensor" and "output speed sensor". Drive the vehicle and monitor the input and output speed sensors. If the sensors show:
^ Continuous output, the wiring currently has no open/shorts. Go to Step 6.
^ No output, go to Step 3
3. Check the wiring harness visually for an open circuit or short circuit to ground. Check for a pinched harness at the PCM/TCM attachment bolts.
4. Disconnect the connectors at the input and output speed sensor and PCM/TCM. Check for bent pins or pins not fully inserted into the connector.
5. If a harness open/short is found, repair or replace the ECM control harness between the PCM/TCM and transaxle and go to Step 8. If not, go to Step 6.
Aug 22, 2011 | Hyundai Sonata Cars & Trucks
Start menu and task bar is not responding for a mean while after i turn on my computer.
Please follow the given steps to relaunch the Start Menu and Taskbar:
1. Press Ctrl + Alt + Del or Ctrl + Shift + Esc to bring the Task Manager.
2. Go to Processes TAB
3. Find explorer.exe and select it
4. Click End Process (Button at Bottom Right Corner)
5. Click File Menu and Select New Task (File-->New Task(Run))
6. type in explorer and press ok
May 18, 2011 | Microsoft Windows XP Professional
I have a hyundai sonata 2007 limited My car has both the esc off and the check engine lights on check engine is always on when the esc off light turns on the car runs very slow, it doesnt accelerate even...
These codes indicate your accelerator position sensor has malfunctioned. The computer has gone into limp mode, which allows you to drive to safety without damaging the engine. The computer is unable to determine how far you are depressing the accelerator and doesn't want to over-rev the engine. You need a new sensor.
Jun 17, 2017 | 2007 Hyundai Sonata Limited Sedan
ESC light. What does it mean
I'm sorry to say that Michael Richardson is incorrect. ESC actually stands for Electronic Stability Control. It monitors the wheels for slippage, and will reduce power (or even apply braking, according to Kia) to a particular wheel if it detects that it has lost traction. For example, say you're driving in the rain and your front passenger wheel hits a puddle and starts to hydroplane. ESC will cut the power to that wheel so that it rolls freely until you get out of the puddle. As it's doing that your ESC light flashes. If you are driving on ice and no wheels have good traction it may stay lit and not allow you to accelerate rapidly because it can control the throttle as well. You can turn off ESC with a button on your dashboard which will result in a yellow ESC Off indicator.
If your ESC Off light is on all the time regardless of the dashboard button or weather conditions, you probably have a problem with your ESC system, which could be as simple as a faulty brake light switch. Kia should be able to diagnose it quickly.
Feb 13, 2011 | 2004 Kia Optima
How to reformat a hard drive?
INSERT THE OPERATING SYSTEM CD ... NOW FROM BIOS SET YOUR SYSTEM TO BOOT FROM CD.... YOU HAVE TO ACCEPT THE LICENSE AGRREMENT IF IT COMES.. FIRST SCREEN WILL BE TO REPAIR THE OPERATING SYSTEM YOU CURRENTLY HAVE..PRESS ESC TO SKIP THIS NOW YOU WILL BE TAKEN TO SCREEN WHICH ALLOW YOU TO MAKE NEW PARTITIONS AND TO FORMAT YOUR DRIVES...JUST FOLLOW ONSCREEN INSTRUCTIONS FROM HERE..GOODLUCK
Jun 16, 2010 | Samsung HD 40GB ATA-6 | HD040GJ - % Hard...
I want to restore the factory settings on my fujitsu siemens amilo Li2727 laptop. i cant find any options to allow me to do this. please help.
You may restore it to its original settings by opening the configuration menu. Usually, this can be accessed by booting your computer while pressing F2 or delete, depending on your computer's model. It will bring you to the configurations menu. Look for the "restore to default setting", highlight using your arrow keys and press Enter, press Esc and go to the exit menu using the tab or arrow key, select save settings and exit. Reboot your computer.
Aug 30, 2008 | Siemens Computers & Internet
GPS Logo
42 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
