Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
Mowing a dry dusty yard- mower running very slowly- some dark smoke also- air filter clogged? thanks
  • Mike Cairns
    Mike Cairns May 27, 2011
    Based on your dusty yard as you stated, it appears as it is loading up by starving it for air. First thing I always do after a mower has been sitting all winter , is fresh gas, air filter cleaned or replaced, new plug and fuel filter.
  • 579 Answers
Sounds like you have restricted the air from going into your carburator to the point the mower is just running. Change the filter and if is that dusty you to may want to put on a mask. Be careful. GOOD LUCK.
Posted on Jul 13, 2011
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
Tip
Save your self some starting trouble.
Aside from changing the oil in your lawn mower, to prevent hard starts and possible complications in the future, regularly check the air filter.
Its an often over looked wearable part that can cause a bit of aggravation when starting, and possible rough running.
You want to make sure that it is not clogged with debris and not extremely dirty. You can have a fairly new filter or machine, but if its dusty, or dry where you mow, it can clog up fast.
When your air filter becomes clogged, it inadvertently chokes the engine causing it to pull too much gas into the engine which leads to flooding of the engine, and the engine not running as well or as efficiently.
In most cases the dirt can be cleaned out if the filter is not really old, and not intensely soiled.
So if your mower seems to be harder to start and it is recent, check the filter. You may be surprised.
on Dec 01, 2009 | Garden
Oil leaking out on yardman mower
You haven't supplied a lot of information but generally when this happens it is due t the mower being tipped the wrong way.
If you must look under the mower then tip it back with the handles to the ground and front wheel in the air.
Now to rectify your problem; The air-filter will probably be saturated with oil. It will probably be the cartridge type which is not serviceable. Purchase a new filter (take your old filter so the sale person can compare like for like). Before you refit the new filter, take out the sparkplug, it will probably be saturated in oil - wash it in petrol, let it dry then refit it. The engine should start and belch out great quantities of smoke. Don't be alarmed this will burn away. Once the smoke has cleared, check the oil level, fit the air filter and mow your lawn.
Jul 18, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Lawn Mower smoking/mufler leaking oil
I have a yardman lawn mower that is two years old. It is now blowing oil out the exhaust and also blue smoke. Any idea what is wrong?
Jul 22, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Jul 14, 2009 | Mtd 22" Yard Machine Push Mower
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Oil leaking from air filter area of push mower and mower smoking
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
Jun 24, 2009 | Poulan Garden
Puchased a rover quick start 6 months ago. No revs
Black smoke should not be coming from your air filter. If however, the smoke is coming from your exhaust this could be the result of dirt clogging your air filter and starving the engine of air, hence causing the motor to run on a rich fuel/air mix. If this is the case clean or replace the air filter element, and keep it clean. Another reason for black smoke blowing out is dirty oil in the crank case, if the oil is very dark brown to black in color or smells burnt then it needs replacing.
Nov 13, 2008 | Garden
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
80 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
