Question about Danby DKC645BLS Compact Beverage Cooler
I have a DKC645BLS and I can't adjust the temperature, like the button are dead. The unit is staying at 41 degrees and the digital display is working fine. Do i just need a new key pad or a whole new control board?
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Posted on Oct 19, 2008
Regulate the temperature on a GE Monagram refrigerator
will need to check ur temperature control switch and ur thermistors all of them in freezer and fridge, have u manually checked the air flow vent to see if it opens and closes ok
Feb 22, 2015 | GE Refrigerators
My frigidaire dehumidifier fad704dud does not turn on when plugged in
Good Morning Robert,
I understand your Frigidaire dehumidifier, model# FAD704DUD, does not turn on when it is plugged in. I also see that the display lights up briefly and there are no error codes. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). It will not work properly if the temperature is out of this temperature range, or the performance of the unit will fall greatly. The "Compressor" circuit has an automatic 3 minute time delayed start if your dehumidifier is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on. If you are still having trouble, you can contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Dehumidifiers
Temperature controller malfunction
the adjustment dial , they are usually dirty from accumulated dust . at any auto parts store you can purchase a can of electrasol , unplug unit , spray into the middle of the switch, as you turn the switch, rapidly all the way around in both directions , repete this .. 2--3 times . look if possible, at the connections on the back of switch are clean ,and have good contact ... let device dry completely before plugging it back in and turning unit on.. let me know , good luck StevenT...
Jan 04, 2014 | Danby DKC645BLS Compact Beverage Cooler
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
What is the procedure for recalibrating the digital oven temp control for a built-in, dual element electric unit?
Oven will be off, of course.
Depress the Bake button; hold it down for 5-7 seconds.
The default offset of 0 will appear in the numerical display. Or, if the oven has previously been adjusted, you'll see that setting. Use the 'up' or 'down' arrow to adjust the temperature by the desired amount. The adjustments are in increments of 5 degrees F. Maximum adjustment is 35.
Press 'Start' to save the new setting.
I recommend rechecking the oven temp at this time. I expected to see a 25 degree increase, but all I got was 10.
Jan 24, 2010 | Whirlpool Ovens
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Thank You
Huuum
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Danby DKC645BLS Compact Beverage Cooler Logo
37 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
