Question about Bernina Artista 180
Thread knotting and bunching on the backside of design
I have been trying to embroidery and all of a sudden my machinge is knotting and bunching on the back side of the design. From the top it looks great but when you take the hoop out the back is horrible. What can I do? This is very frustrating.
    Problem Solver:
  • 8 Answers
Knotting or looping on the bottom is most likely from not enough upper thread tension or way to much bobbin thread tension.
When you thread your machine, make sure the thread goes inside the second thread guide where the thread comes down in front of your machine. The presser foot must be in the up position for that guide to open and allow the thread to correctly "seat" in that guide.
Try this...Before you thread the needle, pull on the thread. With the foot in the up position there should not be any tension at all...lower the foot and you should have to tug slightly on the thread to get it to move. If lowering the foot does not increase your upper thread tension then you are not in the thread guide correctly or you have a mechanical problem with the upper thread tensioner.
One last thing to check. You can get a wax build up or lint packed in the thread tension guide. This is a common problem. Run a Q-tip through the guide and clean it out. If that guide gets built up with wax or lint it will not clamp down on the upper thread and you will not have the correct tension.
With the bobbin case threaded, pull out the thread. It should not be super tight or loose. It should be like pulling Scotch tape off a roll as far as tension goes.
Get your upper and lower thread tensions set up correctly and your problem will be solved.
Good luck, bushvideo
Posted on Sep 27, 2008
I have mc9900 janome when trying to embroidery on t-shirt material threads bunch up in back and I end up with holes in shirt
Are you using a fabric stabilizer to prevent the t-shirt fabric from stretching?
Also, be sure to Always Raise the presser foot when threading the top thread. Knots could be bird nests.
May 08, 2017 | Janome Sewing Machines
What is wrong when the underside of embroidery has bunched thread
The bunched-up thread on the underside is the needle thread. Check that the upper thread is threaded correctly, passing through all the required thread guides and that the thread is securely lodged in the tension assembly ... there should be reasonable tension when upper thread being pulled by hand.
Also check that:
- there are no 'dust bunnies' or a piece of thread hiding in the tension assembly, and that
- the needle is inserted correctly and that it is a system 130/705H Embroidery needle.
Happy Stitching
Apr 23, 2017 | Sewing Machines
Machine will not look stitchesw also bundles up bottom thread
increase the needle thread tension as it indicates that the tension is not tight enough
Feb 26, 2017 | Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Thread bunches up under material
Utter rubbish Connie....look at this comprehensive solution that is why I wrote it !!
to Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Nov 15, 2011 | Sewing Machines
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Embroidery sewing machine stopped working
I am not sure what you mean: motor runs but nothing else moves?
Have you have turned the machine off and tried again? Like computers, sometimes they need rebooted.
More information is needed to evaluate further.
Dec 29, 2008 | Husqvarna Designer I
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Sewing Machines Logo
362 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
