Question about Husqvarna Garden
It starts with choke. runs fast for short time then dies
  • Husqvarna Master
  • 2,239 Answers
Fuel starvation, replace the fuel filter in the tank on the end of the fuel hose, check the fuel hose up to the carb for splits or cracks.
Posted on May 28, 2011
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Starts with choke, disengage choke , runs a short while, then sounds bogged down & dies.
Could be a couple of things. First guess is the carburetor is bad. Because when the saw goes from the choke circuit to run it dies.
Apr 20, 2014 | Husqvarna Garden
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
Mower cranks with throttle in choke. after cranked and throttle moved to fast or any other position. The mower dies as if someone turns it off??
Ok I assume what you are trying to say is that once it starts with the choke on and you turn the choke off it dies.
This behavior usually means that the engine is leaning out. This means that it is not getting enough gas. Often if you put it back to choke fast enough it will keep running though very roughly.
The problem is the main metering jets are plugged or there is some kind of obstruction in the carburetor. This is assuming of course that the tank is full of gas and the fuel filter is clean.
Aug 17, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Runs but quits
Probably gummed up carb. If you don't want to try to rebuild the carb, then try adding a really good carb / fuel injector cleaner to the gas/oil mixture. don't forget to use a very small amount, then run the motor as fast as it will go for short periods of time to try and dissolve the gumming in the jets.
Aug 28, 2012 | McCulloch Garden
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
My 3 year old Yard Machine 139cc started (choke out), but then began running excessively fast after pushing the choke back in. A few weeks later, it still started (choke out) but now ran very fast even...
Check the carburetor see if all the bolts are tight.check the cylinder head gasket take off plug wire make sure it is away from plug so it wont start. Pull start rope can you hear air being pulled into the engine? if so the head gasket has ruptured or head bolts came lose. Ensure all parts are tight. Ensure fuel lines are not clogged. Check fuel level.
Sep 11, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
My troybuilt yard pony riding lawnmower will start with the choke fully open and then dies immediatly when you take the choke off. It will only start and run with the choke fully open, but dies after 20-30...
Do you mean that you can start it normally using the choke (that would be choke CLOSED), but then it dies immediately when you move it to run (that would be choke OPEN)? And if you leave the choke in the starting position that it dies after 20-30 seconds?----- If I have that all right, then you definitely have a restriction in the gas supply. Drain all of the gas from the mower and don't use any old gas. If you have any more old gas (from last season) don't use it. If this mower has a gas filter, replace it. Put just a little fresh gas in the tank plus a little of the cleaner. Start it up, do that a few times if needed. Use a fuel additive such as Sea Foam to keep the gas from gumming up so fast.
Mar 15, 2010 | Troy-Bilt Garden
Garden Logo
41 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
