Question about Sharp Heating & Cooling
My air conditioner shuts off after about 20 minutes
22yooper
  • 828 Answers
SOURCE: RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Posted on Jun 16, 2008
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
SOURCE: Air conditioner runs for several minutes then
Take it back to the dealer and have them fix it, could be a compressor froze up or a fan froze up. If you disconnect the compressor and turn it on and it trips the breaker the fan is probably
bad. If you disconnect the Fan and turn it on and it trips the breaker
it is you compressor.
Posted on Jul 16, 2010
hvac1960
  • 2133 Answers
SOURCE: when the air conditioner is turned on to cooling
Check condenser coil. Dust blocked. Clean it. May be fan motor and compressor capacitor weak. Replace it.
Posted on Jan 16, 2011
  • 10 Answers
SOURCE: My air conditioner amana ac
Either its out of frion, or it needs to be cleaned.
Posted on Mar 31, 2011
Air conditioner cools for 30 minutes then stops cooling after 20 minutes starts cooling again what is likely problem
The compressor motor is over heating and thermal protection shuts it down , when it cools down it restarts. Restricted air flow over the cooling coils could be the cause. Check filter,Sometimes furniture or other things block the return air vent.
Aug 27, 2014 | Heating & Cooling
After my air conditioner is on for awhile it will automatically shut off completely then after a few minutes it comes back on. It is not set on the energy saver setting. Also it is and continues to do...
Debi, it;s not unusual for an AC unit to turn ON & OFF. Once it reaches the temperature that you have it set ON and holds the temperature for 4 or 5 minutes, it will shut OFF until the room temperature rises above it. Be sure all the doors and windows are closed and no hot air is infiltrating the area.
Also, a 10,000 BTU air conditioner is not designed to handle a large area. Generally, 10,000 BTU's will handle about 3200 Cubic Feet (20' x 20' x 8' = 3200 sq ft) or simply put, 400 square feet. Your A/C unit may be undersized for the area you're trying to cool.
Hope this helped you. Please let me know. Thanks.
Jun 07, 2011 | LG Electronic Window Air Conditioner
Shut off automatically, and I run it in fan only mode
Remove filter cover and see if front coils /fins are frosting up. Let me know
May 17, 2010 | Dometic Rooftop RV Air Conditioner
My LG window ac continues to shut down after 20 or 25 minutes
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Aug 01, 2009 | Samsung AW0603B Air Conditioner
LG 1200 btu ac unit works fine for 20 minutes then shuts off compressor and continues to run fan only. Shutting it off for 15 minutes and then works fine again for 20 minutes.
You do not say if it is outdoor or indoor fan which operates. However I presume all your filters are clean and the drainpipes are clear. The only other thing you could suspect is the thermostat or air flow sensor.
Jun 25, 2009 | LG Heating & Cooling
Brand new right out of box Everstar MPK-10CR-1 portable 10,000 BTU's
It sounds to me like it is overheating. Make sure that all of the literature that came with the unit is accounted for. Many times the manual or instructions are blocking the exhaust causing it to overheat. If this is not the problem then I would suggest exchanging it for a new one. It may be a manufacturer defect.
Jun 27, 2008 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
231 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
