Question about Vtech 9009111 Cordless Phone
Why does vtech not have a speed dial? my son is
Why does vtech not have a speed dial? my son is disabled, has one good finger, so need that he can call me in emergency, using one number like #2....thank you
  • lumaze May 27, 2011
    said it all
  • 1,116 Answers
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
Posted on May 27, 2011
  • 3 more comments
  • Gale Todd May 27, 2011
    Was that helpful to you?
    If you copy and paste the link below, you can get more information on the setup of you V-Tech phone:
    http://www.vtechphones.com/vtechphones/i...
    I feel like a dum dum, where is program? one says press phone then memory, at a loss sorry
    Below the * key on the left had side of the phone
    Bottom Row, left hand key is prog, middle key is mem and right key is redial
I have an elderly parent that keeps dialing the emergency number by mistake when he has no signal and the Emergency number is the only option. Is there a way to block that?
PDF]Anonymous Call Rejection Automatic Busy Redial ... - HTC
www.htcinc.net/.../Calling_Feature_Instruc...
Horry Telephone CooperativeDial "*87". 3. Listen for confirmation tone, hang up. Automatic Busy Redial. Available ...There's no need to run to answer a ringing phone ever again! ... number will not be announced if the caller chose to block the delivery of his phone number. ... may onlyreceive calls from the number that you have forwarded your calls to.
Is there a way to completely disable the dialer including ...
android.stackexchange.com/.../is-there-a-way-to-completely-disable-the-...
Mar 26, 2014 - The phone has no service, but can still make Emergency calls and I'm ... you can dial 911 in a country where the landline emergency number is 11 .... The SIM card is just a memory chip, containing authentication information. ... the SIM card, the phone will request access to the strongest signal available, ...
Dec 28, 2015 | Cell Phones
Alcatel cel ph model OT510APIB procedure for turning off emergency speed dial number
Please go to "Menu"-> "Settings"-> "Call settings" -> "Speed dial"->Select a number -> "Options"->"Edit", then select a contact number.
you must do this for every speed dial number you wish to delete!
Easy as...
Mar 11, 2015 | Alcatel Lands Phones
Need to cancel speed dial numbers
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Feb 02, 2014 | Vtech Lands Phones
How do i use speed dial
Since you neglected to specify the model of your VTech 5.8GHz phone, I can only suggest you enter it into the search box here to download a copy of the manual.
Oct 04, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How to use speed dial on v tech dect 6.0 phone
Since you didn't bother to tell us the model of your VTech DECT 6.0 phone, enter the model number into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to get the manual.
Sep 01, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Programming speed dial
I have C110 and it does not have a speed dial function
Jun 10, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Saving phone numbers
hello tjfred.
try here see if your phone listed 5.8 GHz VTech® then click
more info link when you see you phone for the manual.
riz.
May 12, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
Jun 02, 2007 | Vtech ia5823 Cordless Phone
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Vtech 9009111 Cordless Phone Logo
207 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
