Question about Dryers
AF on digital Whirlpool Cabrio dryer. I have taken my electric blower and cleaned the pipes. When the tubing is NOT connected to the back of the dryer, with the dryer on, no air is even coming out!?!?!
  • Dryers Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Most likely the hub on the blower wheel is damaged.
The Blower Wheel is item 10 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515181&diagram_id=28198922#d28198922
I used this model number: WED6600VW0 The blower wheel is not model specific...
Some things to check... in the lint filter area make sure the recepticle is free of lint. Wash the lint filter with vinegar and water then soap and water if you use dryer fabric softener sheets. They look clean but can be completely clogged.
Thanks for choosing FixYa,
Kelly
Posted on May 27, 2011
Whirlpool cabrio 7.0 cu. ft. Capacity electric dryer will start, turn, and heat. It just won't dry the clothes because no exhaust out of line. The lint trap and the hose has been cleaned.
you have to clean out the dryer too,that's a gas dryer it should be taken apart and cleaned out at least once a year so you don't have a fire.you have to unplug the dryer,pull it apart and clean out the cabinet where the motor is and the gas tube,then clean out the blower wheel and the duct that the lint filter slides into,if the vent line is long stick a leaf blower into the line and blow it out.if you live in ma. and need someone to check it out peter de's appliance is a good service to call 781-438-9442
Feb 16, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer takes forever to dry even after i cleaned the vents out
don't forget the exhaust tube coming from the back of the dryer and leaving the building. those can get pretty restricted with lint. Another place to look is inside the cabinet for lint. Getting these cleaned regularly can prevent a fire.
Nov 20, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
When I turn the Dryer on there is the letters AF start flashing it is running and drys the close but it takes a lot longer than it did when I got it.
I've seen the AF code twice now on my Whirlpool Cabriolet Dryer (wed6400sw1). The first time, we thought it stood for "Auto Fluff", a cycle to keep the clothes wrinkle free...We soon realized the dryer was getting a lot hotter than it ever did before and until I checked the vent stack from the roof, I had no idea that the pipe was blocked with a build-up of lint. I cleaned the pipe from top to bottom by taking it apart wherever I could using a vacuum and every hose extension I could get my hands on. I duct taped these together so I didn't drop it somewhere that I couldn't reach!
The second time we saw the AF code was this weekend. First, I verified the vent pipe was not clogged again. (a good quick test for this is to disconnect it from the back of the dryer and run it unconnected to see if the AF code fires) After some online research, I started taking it apart the back to maybe replace the thermistor or the thermal fuse shown above.
I noticed an odd little piece of ceramic tubing had fallen down to the base of the dryer pan. So I decided to take the heater core apart to have a look. Sure enough, I found my problem. My dryer has two separate groups of springy looking heater wire. You can see that part here as well as the little tube I found. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-element-item-number-ap3953732.aspx It turns out that ceramic tube is an insulator allowing for the two heating elements to exist without touching since they are both powered from the same starting wire point.
Well, my AF code (which is really just telling you the dryer is getting too hot) was being created due to a broken wire which caused the two units to fuse together. It must have been getting really hot. It also had welded itself to the metal backing structure.
I carefully removed the broken wires from the heater element and reassembled to test. Sure enough, it works good again and no AF code, but I bet it doesn't heat as much since I removed one half of the element. I'm going to pick up a replacement heater element tomorrow from the local parts store to restore it like new.
Hope this helps someone!
Mar 23, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What does AF error mean on Cabrio electric dryer
AF on your Cabrio means the Air Flow is being obstructed. Make sure the vent is secure and free of debris at the back of the appliance. Also ensure there is no obstruction where it is vented outside of your home. Lastly, make sure the lint trap is clean. Your dryer will still run normally, but it's best to go through your checklist so no further issues arise.
Dec 21, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What does an AF code mean
you need to clean your dryer vents, must move machine back from wall and remove hose and clean out, you may have to call a vent cleaner, if you have to go farther out in the line..
Dec 19, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
The dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
Nov 13, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio dryer
af on your cabrio dryer means clean your air filter
Dec 14, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Dryers Logo
159 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
