Question about Toshiba 32A33 32" TV
Tv toshiba my tv has red stand by light on and green flashin light..no picture can you help me
  • 86 Answers
There is no signal. Get a better antenna and try that
Posted on Aug 16, 2008
My toshiba tv has no sound,what is causing it to malfunction
I have a Toshiba 52HM95 the red light and the green light keep coming on but I get no picture but I can hear the sound very good what could it be please help
Jan 13, 2013 | Toshiba TheaterWide 52HM84 52" Rear...
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Tv wont turn on no more it was fine this morning then is turn off i try turn on and off the power light turns green the click off again and it turns red flashin plus the sleep light red as well flashin plz...
I had a problem with my Sharp LC-15e1u where it will not turn on
by pressing the LARGE RED pb on top. The power button remains red. It also used to be green. Well I tinkered with it and
found by starting with the power OFF,
Press both Menu & TV/Video
Turn on by pressing the Big Red Button
The power lignt is red for one second then turns green.
The TV Then turns on leaving you on channel 58.
The volume control slides from 0-30-60 and back to 0.
Also there is a small "K" in the upper left corner of the screen.
I'm returning the unit for a Factory warrenty. I bought it on
clearance "AS IS".
I hope this helps...
Mar 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 32A33 32" TV Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
